rear caliper removal question - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 05-27-2014, 01:06 PM Thread Starter
spanknut24's Avatar
Default rear caliper removal question
Ok so I took this week off for some riding and I figured I'd clean her first.Thats when I found a rubber boot or cover was missing on the caliper and the caliper bounces around without it.Go to MoMs to get one have to order it and I have to get the whole seal kit 27 bucks(wont be in till end of week to boot).Before I leave I figured Id ask if the caliper can come off without removing the rear wheel.Service guy takes me to look at a KP in the wherehouse to look at what Im asking about and says I dont need to remove wheel.I figure good. I come home change the oil and start looking at the caliper and I cannot find away to remove it without taking wheel off. Check service manual and it says to remove wheel.If there is away Id be very gratefull for any assistance.If I have to drop it off Im boned probably a week or 2.I dont have the tools to remove the wheel and limited know how which I hope to change.Sorry for the long winded post.
06 Kingpin..
K&N air filter
Victory Drag Pipes
ATS @ +4
VFC III
Tuned by KMC
08 vision premium.. totaled :(
06 kp traded in.
04 vegas lost in flood 2010.
06 hyosung traded in for vegas.
spanknut24 is offline
post #2 of 13 (permalink) Old 05-28-2014, 06:21 AM
I have only had mine off once, but it looked to me as if you had to remove the rear wheel to get the caliper off.
The manual says you have to remove the rear wheel...sorry.
Removing the rear wheel is not that big of a job...
2004 Kingpin Chapin, SC
DanG144 is offline
post #3 of 13 (permalink) Old 05-28-2014, 07:18 AM Thread Starter
spanknut24's Avatar
goin to get a jack and start it. beats waiting till june 24th to get in the shop.wish me luck.anything special I need to know about reconnecting the rear shock when finnished? I need to move the swing arm up over the exhaust to get the axel out.
06 Kingpin..
K&N air filter
Victory Drag Pipes
ATS @ +4
VFC III
Tuned by KMC
06 kp traded in.
post #4 of 13 (permalink) Old 05-28-2014, 07:25 AM
Biggest thing is if you can have another person help put the wheel back on. Its a pain to do alone. Especially getting the caliper lined back up right so the wheel lines up with the axel holes. As for the shock I usually let the bike down to apply some weight and that helps line the holes up for me.
Now owns 2012 Cross Country Tour! 3-9-12
http://patsrides.blogspot.com/
pat0021 is offline
post #5 of 13 (permalink) Old 05-28-2014, 07:30 AM Thread Starter
spanknut24's Avatar
thanks.
06 Kingpin..
K&N air filter
Victory Drag Pipes
ATS @ +4
VFC III
Tuned by KMC
06 kp traded in.
post #6 of 13 (permalink) Old 05-28-2014, 11:11 AM
loosen axle nut and shock bolts before you lift the bike.
Don't for get to slide belt off pulley
When putting wheel back on sliding a 2x4 under tire might help
post #7 of 13 (permalink) Old 05-28-2014, 01:30 PM Thread Starter
spanknut24's Avatar
Thanks. keep the advice commin Im gonna need all I can get. heres a dumb question. Do you strap bike down before or after you lift it to desired height?
06 Kingpin..
K&N air filter
Victory Drag Pipes
ATS @ +4
VFC III
Tuned by KMC
06 kp traded in.
post #8 of 13 (permalink) Old 05-28-2014, 04:44 PM Thread Starter
spanknut24's Avatar
Default help!!!!!!
Ok I got the rear wheel off.Now I cant seem to get the caliper off the bracket. I am using an 11 mm wrench but so far all I am doing is starting to strip it.... Any info on how to get the caliper off will help greatly. here is a pic it is a bolt closest to the pad.
06 Kingpin..
K&N air filter
Victory Drag Pipes
ATS @ +4
VFC III
Tuned by KMC
06 kp traded in.
post #9 of 13 (permalink) Old 05-28-2014, 05:11 PM
Edit, went back and read the first post again. Sorry I cannot help.
DanG144 is offline
post #10 of 13 (permalink) Old 05-28-2014, 05:22 PM
All you have to do is take the top slide pin out of the caliper. Then the caliper will just slide off the bottom slide pin.
99 Kawasaki Vulcan 800 (sold)
2012 Vegas (traded)
2013 Cross Country Tour
Victory Tri-Ovals, Reverse Kit, Lloydz air filter, Lloydz quarter turn throttle ring, PCV, Lloydz Touring cams, HMD Bars, DGD keyless ignition, Rockford Fosgate Amp, klockworks windshield. 119hp 123lbs torque.
jchris56 is offline
