Newb Needs Help Please - Victory Forums - Victory Motorcycle Forum
post #1 of 20 (permalink) Old 05-31-2014, 03:57 PM Thread Starter
Default Newb Needs Help Please
So today I'm cruising along the highway, my 2012 Hardball is working great! I stop for a break and start going again and My speedo is not working, or my gear indicator or my cruise? All were fine before I stopped! Please help!
Focker is offline
post #2 of 20 (permalink) Old 05-31-2014, 04:21 PM
CrossRoads's Avatar
How are your blinkers and your horn? If they're also not working, it's a fuse. Check and replace burned fuse. If horn and blinkers do work, you have a lose connector inside the headlight. Open it up (4 screws) and find the lose connector, and make sure it clicks closed.
CrossRoads is offline
post #3 of 20 (permalink) Old 05-31-2014, 04:55 PM Thread Starter
Yes, everything else seems to be working fine. I will check the connection in the headlight. Thanks
Focker is offline
post #4 of 20 (permalink) Old 06-01-2014, 01:58 PM Thread Starter
Ok so I checked all the battery connections, fuses and took the headlight apart and disconnected the connection and reconnected. My speedo still won't work? The cruise power light comes on but won't set a speed? And the odometer does not work? Any other suggestions?
Focker is offline
post #5 of 20 (permalink) Old 06-01-2014, 04:28 PM
Faulty speed sensor?
post #6 of 20 (permalink) Old 06-01-2014, 07:00 PM Thread Starter
Quite possibly? Where exactly would that be located?
Focker is offline
post #7 of 20 (permalink) Old 06-01-2014, 08:08 PM
I have no idea. That was a wild guess.
post #8 of 20 (permalink) Old 06-02-2014, 06:46 PM Thread Starter
Good guess! That's exactly what it is! Ordered a new one today. Thanks
Focker is offline
post #9 of 20 (permalink) Old 06-02-2014, 07:01 PM
That was a lucky guess on my part, I'm going to buy a lottery ticket tonight. Where is the sensor located so I'll know for future reference?
post #10 of 20 (permalink) Old 06-02-2014, 07:39 PM Thread Starter
There's a plug on top of the transmission with one bolt. Unplug the sensor and remove the bolt and put the new one in and bolt it down and plug it in! 100 bucks
Focker is offline
