victory highball brake caliper piston question. - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 05-31-2014, 09:57 PM Thread Starter
Default victory highball brake caliper piston question.
So I decided to service my calipers today to try and reduce brake drag. When I pulled the front caliper off (banjo still attached) I noticed only one piston was compressing when pulling the brake lever. It seems to be stuck in. Any tricks to pull it out without the piston puller pliers ? I sprayed some cleaner on it but can't seem to free it up. Was hoping to do this without separating the caliper halves and draining the fluid.
bigsteveo is offline
post #2 of 5 (permalink) Old 05-31-2014, 10:36 PM Thread Starter
Default Rtfm
Nevermind. Got it. Had a case of RTFM.
READ THE FUCKIN MANUAL
took off banjo and short bursts of air freed it up.
post #3 of 5 (permalink) Old 06-01-2014, 09:01 PM
Default everyone does it!
if all else fails read the directions, we all do it! i will remember your solution forums teach us thru others, thanks for posting the solution
rodhotter is offline
post #4 of 5 (permalink) Old 06-02-2014, 12:06 AM Thread Starter
Yeah it says calipers and brake lines should be flushed and serviced at 12.5 miles. I'm almost at 28k and never did it. I was beginning to think my front rotor was warped from the odd braking feel in front....turned out only one piston was compressing while the other was stuck open....was simple really. I didn't replace seals or anything. ...nor did I separate the caliper. Just took off the banjo and removed caliper and a few short bursts of air where the banjo threads in shot the Pistons out....watch ur fingers ! I put a block of wood between them so they wouldn't shoot all the way out. Then I just cleaned the Pistons and filled/bled the line w dot4. Front brake is super tight now. Tons of pressure.
post #5 of 5 (permalink) Old 06-02-2014, 09:06 AM
BP6666VR's Avatar
NICE, good it all worked out..... brakes are "almost" as important as acceleration,
Be safe out there mate
I printed the manual of Bbob links, on A3 size, not exactly the right year but that really does not matter....
Cross Country Tour 2014 [B]
BP6666VR is offline
