Tri-Oval Performance? W cams, wheel, pcv - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 06-02-2014, 01:54 PM Thread Starter
bsbabcock's Avatar
Default Tri-Oval Performance? W cams, wheel, pcv
In case you were wondering here how Tri Oval's do with some mods.
In a nutshell, not bad. Best? Surely not. But made a nice torque curve I think. Every bike is different. This is what I pulled with it raining and steamy at the SEVR. How she runs now is indescribably nice, in every scenario, cruising, pulling, putt-putting, WOT, and any RPM. The tri-ovals do sound better also once you open up the air a bit with the VM1's, filter and air shroud removal, and have it tuned correctly.
Can't tell.. Maybe one of these pics will work.
2013 Hard-Ball - Lloydz VM1-DR cams, air filter, timing wheel, PCV, properly tuned at KMC
Master, Biltmore Lodge #446, AF&AM
bsbabcock is offline
post #2 of 10 (permalink) Old 06-02-2014, 02:16 PM Thread Starter
bsbabcock's Avatar
Maybe this'll work straight from phone.
Sent from Motorcycle.com App
post #3 of 10 (permalink) Old 06-02-2014, 03:36 PM
RedRocker's Avatar
Post
Very nice numbers! Congrats! I agree, those mods do make the 106 motor that much better.
I had basically the same numbers on my 2011 XC, minus the wheel, when Kyle tuned it last summer. Waiting for him to get back to his shop in RI to make the magic happen on my new XCT.
Dave
USCG Retired
2014 Sonic Blue/Silver XCT
Lloydz VM1-DR Cams/ATS/Air Filter/.25 Turn/PCV/Vic BlkTip Tri-Ovals/Tuned by KMC Powersports: 111/112 CR's H/L HID Kit/Glenda LED's/Hyperlites/Stebel Air Horn/Vic Black Billet Floorboards-Primary&Cam Cover
2011 XC-Traded
RedRocker is offline
post #4 of 10 (permalink) Old 06-03-2014, 09:31 AM
Similar numbers on my CCT from The Vic Shop. Rylan commented that the Tri Ovals always seem to produce a nice 'table top flat' torque curve. Congratulations and have fun on your properly tuned Victory.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #5 of 10 (permalink) Old 06-03-2014, 10:24 AM
Motorbikerx's Avatar
cams certainly keep the HP ramping up.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 10 (permalink) Old 06-03-2014, 10:46 AM
slickvic's Avatar
Nice and congrats !
You will love every mile.
slickvic is offline
post #7 of 10 (permalink) Old 06-03-2014, 11:09 AM Thread Starter
bsbabcock's Avatar
Might be the combination of the wheel at +4 and the VM1's.. More probably all parts, cams, filter, wheel, and tune, but it's amazing even at idle she's like a completely different engine.
While the cams I've read are a fairly mild profile, the bike is ultra responsive, simply smoother and less strained. It shows you a stock 106 is "strangled", for lack of a better word. I can never go back now having experienced it. She now breathes in deep and says "ah smell the fresh air".
I would venture to be as bold to say it wouldn't surprise me if reliability over the long haul may be actually improved. I suspect the mileage as well.
post #8 of 10 (permalink) Old 06-03-2014, 07:15 PM
Yes, certainly its the right combination.
Compared with my 'little' 100 cube on dyno graphs,
Im around ten horse shy of a well breathing 106,
The 106 keeps the HP rising where my 100 tails off.
My torque, breathing well and at 4deg, is comparable to the 106, and comes in strong earlier, but the cubes certainly pump the HorsePower curve.
Add the cams and my 100 is annihilated in both torque and horsepower!
Although my only saving grace is stronger torque down low, but once past 2500 all bets are off.
Cubes, Cams, and the extended revs make all the difference.
To a well breathing engine of course.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #9 of 10 (permalink) Old 06-03-2014, 10:26 PM
100% agree. On my first ever ride on a CCT my thoughts were this is a great motorcycle but the engine and exhaust seem constipated. I have Lloyds DR cams, Lloyds timing wheel, Lloyds air filter, Lloyds 1/4 turn throttle ring, Tri Ovals, PCV and a dyno tune from The Vic Shop, That netted +30hp, +20ft.lbs of torque, +3mpg and a LOT less engine/exhaust heat compared to a stock 106.
All the best,
Mark
"Thank you."
"Who makes it?"
"No one."
post #10 of 10 (permalink) Old 06-03-2014, 11:22 PM
slickvic's Avatar
There is something to be said about a great running motorcycle. It will keep you loving it and most of all keep you wanting to ride it as much as possible. These bikes come from Polaris with well thought out engineering in handling and comfort. Polaris put a large displacement power plant into an awesome designed frame and they left the rest up to us. With the help of dedicated Victory tuners we get the opportunity to make it even better. As proven time and time again by so many here on forums and the open road you can have this great running bike too. All you have to do is tune it!
slickvic is offline
