Final drive belt. How many teeth? - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 11-10-2011, 02:40 PM Thread Starter
half_crazy's Avatar
Default Final drive belt. How many teeth?
I found some belts:
http://www.fullthrottlemotorsports.c...DRIVEBELTS.htm
Questions are, will 1-1/8" belt work?
How many teeth on a Stock Kingpin belt?
I have a 2 teeth smaller front pulley and need a shorter belt (axle is all the way back). If the stock belt is 141 teeth I should be able to use a 139 tooth belt, right?
Input appreciated!
2006 Victory Kingpin
half_crazy is offline
post #2 of 5 (permalink) Old 11-11-2011, 05:11 AM Thread Starter
half_crazy's Avatar
Bump.......
post #3 of 5 (permalink) Old 11-11-2011, 08:18 AM
ammo_umb's Avatar
I can't tell you anything about the KP belt but on my XR measuring from the outside edge of 1 tooth to the outside edge of a 3rd tooth is 27mm. This logic eliminates 2 teeth so if I were looking for a shorter belt I would look for 1 with the same spaceing. This should pull your rear axle 13.5mm forward.
Retired USAF, IYAAYAS!
ammo_umb is offline
post #4 of 5 (permalink) Old 11-11-2011, 10:13 AM Thread Starter
half_crazy's Avatar
I believe the 14mm pitch on the belts is correct...
It looks like I'll just have to count the freakin' teeth. I can take my OEM front pulley and set it in a Harley belt and check the pitch that way.
post #5 of 5 (permalink) Old 02-20-2012, 09:27 AM Thread Starter
half_crazy's Avatar
Answered.
The OEM belt on the 2006/2007 Kingpin is:
14mm pitch, 1-1/8 wide, 147 tooth.
What I need is 145 tooth. I e-mailed Gates and they have nothing. My friend was doing some research and found that the belt for a Buell 1125R is 145 tooth (A Goodyear Belt).
This belt is 1" wide, but if it handles the power of a Buell 1125R, it should be OK.
