Running Rich? - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 06-05-2014, 04:36 PM Thread Starter
Big Tav's Avatar
Default Running Rich?
Hi guys, I know our bikes are know for running a bit lean especially with stage 1 upgrade. I have Swepts and the Stage 1 with K&N Filter.
I asked before if I pulled the stock swept baffles and put in RPW baffles would it run too lean. I had a few replies saying that the Stage 1 tune was barely enough to keep up.
The thing is that I pulled the O2's out of my bike and they are really black. The ends of the pipes are quite black and sooty too.
From the pics would you not say my bike is actually running rich?
2015 Highball Black - Mods being done now!
Suzuki M109R L0 - Sold
BMW K1200R - Sold
Suzuki TL1000R - Sold
2014 Victory Hammer S - Sold
2012 Victory Highball - Swept Pipes, RPW Baffles Stage 1, 02's Removed, Lloydz Timing Wheel 4+, 1/4 Turn Throttle Ring, Mini Bullitt LED Indictors, Kewl Metal Brackets, Arlen Ness Pegs & Grips, Arlen Ness Cam Cover, K&P Oil Filter, Magnetic Sump Plug, Rear Axle Covers, Black Engine Bolt Kit. - Now Sold :(
Big Tav is offline
post #2 of 8 (permalink) Old 06-05-2014, 04:54 PM
Lostintexas's Avatar
What do your spark plugs look like?
Looking at the O2 sensors may have some merit, but spark plugs tell the story of what is happening inside. Unleaded fuel has a reputation of leaving soot deposits even if everything is in proper order.
Cheers
I ride with the Force.
Lostintexas is offline
post #3 of 8 (permalink) Old 06-05-2014, 06:47 PM
dtmmil's Avatar
O2 s and tailpipes are going to be black , its due to crap we get for gas nowdays. check your plugs after doing plug chops , that will tell.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #4 of 8 (permalink) Old 06-05-2014, 10:26 PM
Default That's rich
That o2 sensor has been in a rich mixture.
Where it is rich I couldn't say. If you had pulled those out after running 100mph for a mile at full throttle and they were that cold then I'd say you have a problem. However if the bike had been idling or running very slowly for a couple of blocks and then idling it would mean that you are rich in your very low speed cells of your fuel map.
For what that is worth...
If the motor had not reached operating temperature before it was shut off it would not indicate as rich a condition as if it had been at operating temperature.
But to answer your question yes that is what rich looks like.
Joe_ is offline
post #5 of 8 (permalink) Old 06-06-2014, 08:37 AM
Motorbikerx's Avatar
Agrees..the spark plugs tell the story of whats happening inside the combution chamber...those 02 sensors are downstream in the sooty exhaust pipes...No indication whatsover
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 8 (permalink) Old 06-06-2014, 12:12 PM
Vicbuilder's Avatar
A Victory without a fuel controller will run extremely lean at cruise, and very rich at high throttle/load conditions. So the answer to "Running Rich" is both yes and no.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
post #7 of 8 (permalink) Old 06-06-2014, 12:26 PM
dtmmil's Avatar
this statement to me is why a pcv or the new vfc4 is the way to go
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #8 of 8 (permalink) Old 06-06-2014, 12:30 PM
CrossRoads's Avatar
Yea, the biggest change I noticed in going from the Cobra Fi2000 to VFC4 was the WOT part. It makes sense that I was running too rich before at WOT.
CrossRoads is offline
