Need help removing rear tire/muffler on Jackpot - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 06-08-2014, 04:26 PM Thread Starter
Default Need help removing rear tire/muffler on Jackpot
I need to replace the tires on my 2008 (Cory Ness) Jackpot but can't figure out how to get the rear tire off. It looks like i need to take the mufflers off to pull the axle but I can't seem to get them to separate. I've loosened the clamps at the front and removed the bolts from behind the bracket but I can't pull them apart. I'm hesitant to pound on it or try prying with anything for fear of damaging the chrome. Can anyone tell me how to separate these?
Also while searching I found references to unbolting the rear shock as an alternative to removing the mufflers but that was in a kingpin forum. Would the same method also work for a jackpot?
Thanks in advance.
elkhunter is offline
post #2 of 16 (permalink) Old 06-08-2014, 04:38 PM
where the mufflers meet the header pipe there are clamps. Un do the clamps
Un hook the shock at the bottom.
Un do the axle nut now tap it enough to pull the axle plate out on the other side
Now jack the bike up
loosen all bolts before lifting bike off ground
post #3 of 16 (permalink) Old 06-08-2014, 05:38 PM Thread Starter
Thanks but a little confused. Do I still need to do anything with the mufflers if I go the route of disconnecting the shock? I didn't think I had to do anything with the mufflers using that option.
Also regarding the clamps, I did loosen them but didn't completely remove them as they looked like they just slid apart and what information I could find online simply said to loosen them. Do I need to completely remove them to get them to pull apart? I'm guessing mine are just rusted together but I dont want to pound on them.
Thanks again.
post #4 of 16 (permalink) Old 06-08-2014, 06:08 PM
If you have jack un hook shock and jack it up.
Tire will stay on ground and when you get bike high enough full tire out at a angle.
Look on youtube for video
post #5 of 16 (permalink) Old 06-08-2014, 08:00 PM Thread Starter
Are you sure this procedure works on a jackpot? I just removed the lower bolt on the shock (that wasn't easy and I sure hope I can get it back in) but when I lift the bike the tire still lifts with it. It looks like it's about 1" lower than before but still hidden behind the mufflers.
Any tips on getting that bolt back in? I have a nice lift but whether I had the full weight, partial weight, or no weight on the rear wheel it was really hard to get out. I suspect it will be harder to get back in.
post #6 of 16 (permalink) Old 06-09-2014, 11:59 AM
spanknut24's Avatar
different (kingpin) bike but i had to unbolt not only the shock but there were 2 arms that went with it. so 2 bolts total.gettin it back together wasnt easy but not too hard . 2 people is definetly better than 1.
06 Kingpin..
K&N air filter
Victory Drag Pipes
ATS @ +4
VFC III
Tuned by KMC
08 vision premium.. totaled :(
06 kp traded in.
04 vegas lost in flood 2010.
06 hyosung traded in for vegas.
spanknut24 is offline
post #7 of 16 (permalink) Old 06-09-2014, 12:15 PM
Default we all need help at times but!
buying a shop manual or downloading + printing one is what anyone that works on their bike needs. i recently created unneeded xtra work because i did not read the manual. ordered one the first night i brought the my 13 hammer home, first Vic for me + i love it!!!
rodhotter is offline
post #8 of 16 (permalink) Old 06-10-2014, 08:42 AM Thread Starter
I looked at the service manual for an '06 jackpot (which should be fairly similar to mine) and it said to remove the mufflers. It doesn't really say how to other than to loosen the clamps, remove a couple bolts, then slide it rearword to remove. I just couldn't get it/them to budge. Anyway, I put it all back together and am taking it to the dealer to have them do it. They charge $68/wheel which seem reasonable.
post #9 of 16 (permalink) Old 06-10-2014, 11:26 AM
If the X bikes are the same, here's how this 77-1/2 year old did it sonny, but it requires a helper person.
+ Raise the bike on a lift--one of those two arm types.
+ Place a car jack under the rear tire and have helper person apply a wee bit of pressure to eliminate the stress from the shock bolts.
+ Remove the 2 shock bolts and have helper person slowly lower the jack all the way.
+ Remove axle and wheel.
+ Reverse process to replace wheel.
post #10 of 16 (permalink) Old 06-10-2014, 11:46 AM
Default doing your own work?
doing your own work is not for everyone as you need tools + equipment that cost $$. sometime there are friends close to help, then there is an independent. if you find a good one its always less than a dealer, he has a lot of overhead $$$. better let someone else do it sometimes rather than fxxx it up!
