Tire question - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 11-22-2011, 09:49 PM Thread Starter
Default Tire question
So I need to get new tires and I have a question. In the manual for my bike it says that I need Dunlop 160 or for whitewalls 150. My question is what's the difference? I know the difference between 150 and 160 is the width but I mean between blackwall and whitewall. Can I use any 150 or 160 or is that only applicable for whitewalls? I'm asking because I'm trying to find the best prices on tires and I'm wondering if Pirelli 150's will work. Thanks.
03 V92C Classic Cruiser
guitarman is offline
post #2 of 7 (permalink) Old 11-23-2011, 05:43 AM
vindex1963's Avatar
I know the load they are rated for is critical.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #3 of 7 (permalink) Old 11-23-2011, 07:27 AM
handyhoward's Avatar
Whitewalls are laminated onto the tires... that's why a 150 in whitewall will measure out to be about the same as a 160 in black. I have found that Pirelli makes excellent motorcycle tires... they were one of the pioneering companies in developing multi-compound tires and are a leader in racing tires.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #4 of 7 (permalink) Old 11-23-2011, 05:05 PM Thread Starter
Thanks for the info. I've heard lots of good things about pirellis that's why I've been looking at buying them. But the problem is I can only find 150 for the rear wheel in pirellis with blackwalls. I don't know much about tires so I was just wondering if I can put the 150s on my rim even if the manual calls for a 160.
post #5 of 7 (permalink) Old 11-24-2011, 06:19 AM
Default tires
gman: you probably can, it depends on your style of riding whether you would ever notice a difference. if you're like 99.5% of us, you probably won't notice. although you're talking about a slightly narrower tire all of the standard warnings apply here. always check and re-check for fitment and obstructions (rubbing etc.) before you ride it. ride safe.
2002 v92c deluxe/ 1970 flh bobbed
swatsonv92 is offline
post #6 of 7 (permalink) Old 11-24-2011, 06:28 AM
As stated, you probably can... make sure that your rim width is rated for a 150 and that the tire that you get is rated for the correct weight and speed.
Handy
post #7 of 7 (permalink) Old 11-24-2011, 05:27 PM Thread Starter
Thanks for the answers. I'll probably just get some metzlers, I was looking hard at the pirellis because they were cheaper than the metzlers, but metzler makes a 160. I've heard lots of good things about both brands and lots of bad things about dunlops. I'm definately not getting those.
