Does power commander stress the engine??? - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 06-16-2014, 02:50 PM Thread Starter
bcflyguy's Avatar
Send a message via MSN to bcflyguy
Default Does power commander stress the engine???
I am trying to trade my 2012 cct for an Indian Vintage. The dealer is telling me that due to the fact that a power commander was installed, the bike has been stressed and he won't take it in trade. Any truth to this crap???? comments please guys
Thanks
Kelowna British columbia Canada
1 2012 cross country tour arlin ness big honkers/ fuel controler/air mod, Bag rails, Ostrich 2 up custom seat, Sheepskin seat cover, trunk rack. Bag locks
2 2013 cross country tour . Trunk removed. ness honkers lloydz air box, bag rails Rich's custom gel/ ostrich seat .Bag locks. chrome pass boards. Ignition relocate.Kury mirrors,
bcflyguy is offline
post #2 of 19 (permalink) Old 06-16-2014, 02:57 PM
Defuse's Avatar
Sounds like shady dealer shenanigans to me
2013 Zach Ness Cross Country - #110
Lloydz Air Filter // VM1-DR // PCV // ATS // D&D Unwrapped
110 HP // 110 Ft.Lbs
Defuse is offline
post #3 of 19 (permalink) Old 06-16-2014, 03:02 PM
CrossRoads's Avatar
Originally Posted by bcflyguy View Post
...Any truth to this crap???? comments please guys
Thanks
No truth to it. The PCV changes the fuel mapping. It does not add any stress to anything. On the contrary, the motor runs cooler when taken off the suicidal stock map, and cooler running motor wears less. Who knows, maybe they have too many used bikes in stock and don't want another, and gave you a typical dealer excuse.
CrossRoads is offline
post #4 of 19 (permalink) Old 06-16-2014, 03:04 PM
Squatch's Avatar
Interesting comment. Ask him what the hell he is talking about?
Equipment doesn't stress the engine the operator does.
I can venture a guess that he has seen some poor tuning that has caused some problems either too lean or rich.
Dealer might be skiddish about the emission modification as well.
Cheers
Squatch
USN/USCG Vet
2013 Cross Country Tour
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
D&D wrapped/RPW baffles
Touring Cams
124 hp/119#ft
A country that forgets it's defenders, will itself soon be forgotten
Squatch is offline
post #5 of 19 (permalink) Old 06-16-2014, 03:13 PM
Is that dealer also a politician?
post #6 of 19 (permalink) Old 06-16-2014, 03:46 PM
half_crazy's Avatar
No.
2006 Victory Kingpin
half_crazy is offline
post #7 of 19 (permalink) Old 06-16-2014, 05:06 PM
It depends on how the dealer is looking at this. Normally when someone adds a programmer they are running the you know what out of the bike and I would bet you that is why they don't want to touch your bike knowing you have put a PCV on it.
As far as the PCV hurting the engine, only if it is set up improperly i.e. the air/fuel ratios are way off and it has been driven that way for a long time then sure any programmer could end up hurting an engine. Run it to lean for to long and damage can occur and even running it to rich can cause problems.
Most dealers don't want anything to do with a bike that they think has been driven hard.
I know auto dealers who would not give much in trade for a car that had a trailer hitch installed on it.
Victory 1 is offline
post #8 of 19 (permalink) Old 06-16-2014, 05:11 PM
These dealers are ridiculous. I would find a different India dealer.
My ride
2013 Vision Touring. Shelbyville IL
Lloyds 116 big bore
Lloyds timing wheel set at plus 2
Lloyds adjustble intake
Lloyds HP cams
Lloyds quarter turn throttle
PCV 5
Ness Big Honkers
Lloyds Vision intake plate
Lloyds variable clutch
Heads worked over
Built and tuned by Rylan Vos at The Vic Shop
Adel ia.
136HP 139FTLBS
new vic rider is offline
post #9 of 19 (permalink) Old 06-16-2014, 05:43 PM
ndabunka's Avatar
Thanks
Not if it was tuned right but anybody can screw something up and since a PCV allows the owner to do essentially "Whatever the hell they want to it..." I guess I could see this guys point. If you had it tuned by a professional you could always simply show him the dyno sheet showing that the PCV when properly installed by a skilled tuner ENSURES that the bike has not be "abused" in ANY way. Either than or find a dealer that understands that MANY bikes have power commanders added to them as a normal process.
In fact you MUST use a Power Commander (or other similar controller) should you add CAMs to the bike to ENSURE that it is properly tuned.
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
post #10 of 19 (permalink) Old 06-16-2014, 05:54 PM
Jackpot!'s Avatar
Total b.s., the PCV mapped correctly will actually fix the lean mapping installed by Victory to comply with federal emissions. Lean is heat and an engine that's running warmer than usual isn't conducive to engine longevity. However, a warmer engine does burn up emissions more completely, also part of the reason why they are set up lean. It's not about you or your bike, it's about gov't.
Jackpot! is offline
