Oil cooler - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 06-19-2014, 09:26 PM Thread Starter
Default Oil cooler
Was wondering if I could remove my oil cooler without any problems for motor/trans. I put new exhaust on and it requires to remove cooler and by relocation cooler on left frame rail.. I don't like the look of it and would rather just remove it for good if can be done without any issues ..
2009 Vegas,Stage 1 Flash, Bassani Pro Street Turn Outs,Arlen Ness 12" Modular Bars,Arlen Ness Smooth Fusion Grips,Victory HID,Side Mount Custom Plate Bracket and Frame,Arlen Ness 2" Rear Speeding Bullets,1.5'' lowering links...
Cherry/pearl white.
Chicopee Ma. 01020
HoodsBackVegas is offline
post #2 of 10 (permalink) Old 06-19-2014, 09:32 PM
Judge Redd's Avatar
I'm not a pro, but there is no way I would completely remove my oil cooler. Isn't there something you can replace it with that would fit everything in? Oil is a big part of the cooling..
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #3 of 10 (permalink) Old 06-19-2014, 09:42 PM
Motorbikerx's Avatar
I wouldn't, an oil coolers not about looks its there for a purpose.
Id get an exhaust that fits.
Up to you though, maybe its really cold where you live and your engine would survive high oil temps.
Plenty of aircooled bikes dont have oil coolers but start hotting up say a 750/4 or an XS650 or a z900 and what did we add?
Yeah right, oil coolers....and a Vic motor surely
Out-Grunts any of those two put together, possibly all three!
Its there for a reason not just to spoil/enhance the looks of the bike.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 10 (permalink) Old 06-20-2014, 05:26 AM
Weeds's Avatar
As stated, Keep the cooler...
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #5 of 10 (permalink) Old 06-20-2014, 05:37 AM
GatorJoe's Avatar
The Oil Cooler was designed to go with this Engine .. Is not an Add On .. That should explain it clear enough ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #6 of 10 (permalink) Old 06-20-2014, 07:03 AM
Garion12's Avatar
If you need to remove the stock oil cooler, try looking at the conquest customs cooler for steel frame bikes. It looks pretty badass and should work with your choice of exhaust.
2010 Cross Roads
Lloydz Air Filter
Lloydz Slip on Exhaust
Lloydz Timing Wheel 8*
LLoydz VM1-HPT Cams
Lloydz reflesh 6500 rpm
Dyno tuned by KMC 123 hp 121 tq
Garion12 is offline
post #7 of 10 (permalink) Old 06-20-2014, 11:07 AM
are you putting on the Bassani Pro Street if so no one ells has ever said they had to move oil cooler
post #8 of 10 (permalink) Old 06-20-2014, 01:01 PM
Luciferiad's Avatar
The oil cooler on the Vic motor is an integral part of the engine's cooling/oiling system. It's not a crankcase oil cooler. Oil travels from the crankcase to be cooled by the cooler before being fed into the heads from the top down to cool them as well. It is vital to the engine design. You wouldn't take the radiator out of your car, you shouldn't try to remove the oil cooler from your Vic.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #9 of 10 (permalink) Old 06-20-2014, 01:45 PM Thread Starter
Thanks for input I figured that was the answer just want to make sure before any hasty decisions I'd make.. Thanks again boys for all thoughts..
Cherry/pearl white.
Chicopee Ma. 01020
post #10 of 10 (permalink) Old 06-20-2014, 02:42 PM
fargoben67's Avatar
gunna have to spend the money on an aftermarket oil cooler. not cheap but looks cool!
2013 Highball (for me)
Torque Tube intake - VFCIII - Hacker Lake Pipes - Lloydz PTS set at +4 - Blinkers and License plate holder stripped - Side mount plate
2008 Kawasaki Vulcan 500 (for her)
2008 Suzuki Boulevard M50 (miss it)
1989 Kawasaki Ninja 500 (RIP)
Never underestimate the power of stupid people in numbers.
fargoben67 is offline
