Transmission shifter extention rod????? - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 06-20-2014, 12:12 PM Thread Starter
4 inch pistons's Avatar
Default Transmission shifter extention rod?????
I am thinking of moving the floor boards to the forward position on the Cross Roads. I have read the shifter rod for the tranny is not long enough. Since I am not sure I want to keep it there and don't want to make it permanate, where can I pick up a cheap rod? Is there a vendor out there? (A better question may be why did not Ma Vic engineer it with threads long enough to work with OEM?)
[SIGPIC]
[/SIGPIC]
"The Road Goes on Forever and the Party Never Ends"-Robert Earl Keen
4 inch pistons is offline
post #2 of 8 (permalink) Old 06-20-2014, 12:43 PM
dtmmil's Avatar
oh come on now. they are engineers, no one is smarter!!
oh, if you just want to try it, unbolt the shifter from the motor, rotate it to reach and try it. you may have to adjust the rod some too. i had a SS rod made for mine to move my boards forward, just like stock only longer.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 8 (permalink) Old 06-20-2014, 01:13 PM
sgtfixit's Avatar
I moved the connector forward a notch on the input? shaft connection when moving the boards forward. Was not real happy with the feel...ended up purchasing a longer SS rod from DTMMIL, a forum member here who makes them. Got everything lined up just right...no more squirrely shift feel. Works great!
link to thread...
https://www.victoryforums.com/showthr...ghlight=SS+rod
MSgt Ret. Security Forces USAF/Santa Maria, CA
2011 Victory Cross Country (Imp Blue)
-Mods-Vic Military Salute Wedge Covers/Madstad with stock shield/Floor Board Hwy Pegs/2012 Hard Lowers/Hard Bag Bars/adj. pass. foot rests/+2 SRVT Pull Back Bars/Mirror extenders/LED driving lights/WOLO horn/RicZ laid down plate bracket/Kuryakyn Brake Pedal/Signal Dynamics headlight modulator/Custom Dynamics Brake light Strobe/LED rear plate/1/4 turn throttle ring/Lloydz timing wheel +4
sgtfixit is offline
post #4 of 8 (permalink) Old 06-23-2014, 04:11 PM
ptc
ptc's Avatar
Just get a "rod coupling nut" and some threaded rod and extend it temporarily to see if you like then make a new rod.
2011 Custom "Hammered XR"
http://streetbikeusa.blogspot.com/
BBob- "We all share the same wind regardless of the t-shirts we wear"
ptc is offline
post #5 of 8 (permalink) Old 06-23-2014, 04:53 PM Thread Starter
Do you know what thread size?????
[SIGPIC]
[/SIGPIC]
post #6 of 8 (permalink) Old 06-23-2014, 05:13 PM
dtmmil's Avatar
should be 1/4" fine thread, be easier just to rotate the arm one or two clicks though
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #7 of 8 (permalink) Old 06-23-2014, 05:28 PM Thread Starter
I was thinking it would be metric. ?????
[SIGPIC]
[/SIGPIC]
post #8 of 8 (permalink) Old 06-23-2014, 05:32 PM
dtmmil's Avatar
nope
currently bikeless
Hawley MN(sold)
dtmmil is offline
