High Voltage issue - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 06-26-2014, 05:12 PM Thread Starter
Default High Voltage issue
So interesting issue came up for me the other day and any input would be appreciated.
Bike in question - 2008 Victory Vegas 12,000 miles
Issue - During ride engine light came on, later found headlight had blown out. Found voltage spiking at over 18V!!!
Voltage at idle is anywhere from 12-15V and spiking around 3500 RPM.
Dealer is nearly 40 miles away and I do not want to risk any additional damage at running such a high voltage.
As of now I am suspecting voltage regulator but I was reaching out to find out if there are any other techniques I could try to narrow it down a bit further.
The bike had set for nearly a year to what was suppose to be on a battery tender, room mate unplugged it and the battery was completely dead. Being as it had been 5 years I just decided to get a new battery instead of trying to resuscitate.
All connections have been cleaned and triple checked.
New battery - Duralast Gold/Powersport AGM battery ETX20L
2008 Vegas Low Black
Stroker/Big Bore - 116 CI
495 Cams
RPW Slash
PC 5
Torque Tube intake
DaveAFVet is offline
post #2 of 12 (permalink) Old 06-26-2014, 05:20 PM
CrossRoads's Avatar
Originally Posted by DaveAFVet View Post
As of now I am suspecting voltage regulator...
Yep, it's the voltage regulator. You can replace it yourself to save yourself the tow to the dealer.
...but I was reaching out to find out if there are any other techniques I could try to narrow it down a bit further.
It's the voltage regulator. You don't have to try/test anything else.
CrossRoads is offline
post #3 of 12 (permalink) Old 06-26-2014, 05:28 PM Thread Starter
Well that sums it up pretty easily. Thank you for the quick response.
Any vendors that you would recommend? I am kinda disappointed that this one went out with only 12,000 miles.
495 Cams
RPW Slash
PC 5
Torque Tube intake
post #4 of 12 (permalink) Old 06-26-2014, 05:46 PM
saddlebag's Avatar
Not so fast. A voltage regulator that failed to regulate the input ac at high rpm would indeed cause excessive voltage. But a voltage regulator trying to regulate a rectified generator input that lost a phase could also cause an abnormally high reading.
If you've got a scope and can verify that all phases are there and relatively equal, I'd replace the VR, otherwise, replace the stator.
2011 Cross Roads
saddlebag is offline
post #5 of 12 (permalink) Old 06-26-2014, 05:49 PM Thread Starter
I was actually in the process of finding the plug to the stator just so I could check the ohms. Unfortunately the only oscope I have access to is at the office, which I am not allowed to bring home.
495 Cams
RPW Slash
PC 5
Torque Tube intake
post #6 of 12 (permalink) Old 06-26-2014, 05:57 PM
go to any store and buy a volt meter. If you have bad stator and put in a new regulator it will burn it up and your new battery to.
So check stator for out put. FIRST
Guys have found oil or goo inside regulator plug.
When your getting a volt meter pick up some electric clean
post #7 of 12 (permalink) Old 06-26-2014, 06:05 PM
CrossRoads's Avatar
...Any vendors that you would recommend?...
Call or email Paulie. Here's his contact info:
Paul Tomanicek - Parts Sales
(419) 891-1230
(877)-437-1631
[email protected]
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
post #8 of 12 (permalink) Old 06-26-2014, 06:13 PM Thread Starter
Stator checked good for ohms. The connectors do not allow for me to test the voltage while running.
495 Cams
RPW Slash
PC 5
Torque Tube intake
post #9 of 12 (permalink) Old 06-26-2014, 06:50 PM
saddlebag's Avatar
Resistance isn't a bad check, but it induces very little stress into the coils. If the insulation is bad, but not completely shot, inducing operating voltage may be the only sure way to check it.
OTOH, given that the stator resistance checked out, I'd probably be willing to bet on a bad VR and replace it myself. WTH, even if it doesn't turn out to be the problem, not the worse thing in the world to have on the shelf.
Speaking of shit on the shelf. I recently had a fuckload of mice in my attic. I iced them with high quality blood thinners, but recently went up to find my guitar cases clawed all to hell. That was about a month ago.
For whatever reason, it just struck me that I have a pristine set of leather XR bags that probably got shredded by the goddamn rodents too. I'm a little too scared to go up to check just yet.
2011 Cross Roads
post #10 of 12 (permalink) Old 06-26-2014, 09:06 PM
depot picker's Avatar
Shouldn't store guitars in the attic. It gets too hot in the summer and too cold in the winter.
depot picker is offline
