Lloyd'z Idle Air Valve?? - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 06-27-2014, 08:04 PM Thread Starter
MrXC2014's Avatar
Default Lloyd'z Idle Air Valve??
What is Lloyd'z Idle Air Valve for? I'm looking at some add-on's and wondering if it's necessary .
2014 Victory CC, Two-Tone, VM1-HPT-DR, PC5, ATS+4, Llyodz HI-FLOW A/F, 1/4 Turn Throttle Ring, Tuned by Kyle Crandall of KMC PowerSports, Flashed ECM, 121hp 113tq
Suede Supersteel & Black, Madison, AL
MrXC2014 is offline
post #2 of 18 (permalink) Old 06-27-2014, 10:13 PM
It helps with backfire as the standard iav isn't adjustable. From what I've read most people don't see to much difference with it but I haven't tried it so I can't really give you a good assessment. I'm sure someone will chime in that has it or has used it.
2011 vegas 8ball PCV, swept pipes rpw modified baffles, llyodz vm1-dr cam, ats +4, 1/4 throttle, ud pulley and ness intake.
KMC tuned 114hp/125ft/lbs
shanko is offline
post #3 of 18 (permalink) Old 06-27-2014, 10:13 PM
Go to Lloydz web pag and read about it. look at how to instal while your there
post #4 of 18 (permalink) Old 06-27-2014, 10:15 PM
Supposedly helps with lean stall. I assume thus is when the bike stumbles sometimes just off idle.
Sent from Motorcycle.com App
post #5 of 18 (permalink) Old 06-28-2014, 12:29 AM
I had one on a Jackpot and it really helped with popping on that bike so I kept it when I traded it in for the XC and never felt a need to install it on the XC so far. Just didn't have the same problem the JP had. Contrary to popular belief; the steel frame bikes and the touring/bagger Vics are tuned and run different.
post #6 of 18 (permalink) Old 06-28-2014, 05:11 AM
Default cams
When I has my cams installed by Rylan i was gong to have it installed because I had a ton of popping with the ness honkers on my Vision with just the stage one download. Rylan said it would not be needed. He was correct. After he installed the cams and tuned the bike it has not popped in the 2000 miles since.
My ride
2013 Vision Touring. Shelbyville IL
Lloyds 116 big bore
Lloyds timing wheel set at plus 2
Lloyds adjustble intake
Lloyds HP cams
Lloyds quarter turn throttle
PCV 5
Ness Big Honkers
Lloyds Vision intake plate
Lloyds variable clutch
Heads worked over
Built and tuned by Rylan Vos at The Vic Shop
Adel ia.
136HP 139FTLBS
new vic rider is offline
post #7 of 18 (permalink) Old 06-28-2014, 02:29 PM
Installed one on my 08 Vegas. My intent was to improve the off idle throttle response (stalling) and reduce the popping and backfire. After quite a bit of fiddling (adjusting) it, my take on it is this - marginally effective. A slight improvement in the off idle throttle response, not much reduction in the popping and backfiring. You mileage may vary!
2008 Vegas 8-Ball Vic stage 1 pipes, laydown lic plate, Ness fly bars, led brake lights, front turn sig removed, Memphis Shades Demon windshield, Rivco signal mirrors,
timing wheel at +4
mmarsh is offline
post #8 of 18 (permalink) Old 06-28-2014, 06:25 PM Thread Starter
MrXC2014's Avatar
Ok I read the install instructions and got a little better understanding of it. I don't have the popping issue that's what I got out of it the most.
MrXC2014 is offline
post #9 of 18 (permalink) Old 06-28-2014, 07:15 PM
Jackpot!'s Avatar
I just put it on my jackpot, seems to be doing everything it's supposed to do. I still get the occasional pop but nothing like prior to install.
2010 Victory Jackpot, Elkton, Va in the Shenandoah Valley. Tequila gold, Ness Flybars, Victory HID conversion, Lloydz TTI, VM1 cams,PCV based by Rylan, RPW Bad Boy, Lloydz ATS, Lloydz IAV, K&P filter. Goal=106 @130hp
Jackpot! is offline
post #10 of 18 (permalink) Old 07-01-2014, 07:07 AM
deepstuff's Avatar
Question
So whats the general consensus? Do it work or not. Just ordered one for my 08 KP to try and reduce the popping.
2008 Kingpin Premium
Newfoundland,
Canada
deepstuff is offline
