read my plugs? - Victory Forums - Victory Motorcycle Forum
post #1 of 23 (permalink) Old 06-28-2014, 06:57 AM Thread Starter
archaicguy's Avatar
Default read my plugs?
Are the plugs showing a rich condition? These are both from the front cylinder but the rear looked exactly the same. It was dry sooting not wet but it has been almost a week since she was run.
Thanks guys
2016 Cross Country
1969 Firebird
1979 10th Ann. Trans Am
1979 Solar Gold Trans Am
2010 Challenger R/T - Plum Crazy Purple
archaicguy is offline
post #2 of 23 (permalink) Old 06-28-2014, 06:59 AM
LILMAGS500's Avatar
Overall observation : RICH
LILMAGS500 is offline
post #3 of 23 (permalink) Old 06-28-2014, 07:04 AM
dtmmil's Avatar
rich, did it idle for any amount of time before getting shut down the last time?
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #4 of 23 (permalink) Old 06-28-2014, 07:11 AM
Motorbikerx's Avatar
put new plugs in , run it hard up to a high gear , when its pulling hard in say 5th kill the motor and pull the clutch in at the same time,
Roll to a stop then pull the plugs and show us.
That's a plug chop.
anything else is pissing in the wind.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #5 of 23 (permalink) Old 06-28-2014, 07:13 AM
dtmmil's Avatar
but if you put new ngks in they may take a while to color , so dont panic if they are white.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #6 of 23 (permalink) Old 06-28-2014, 07:35 AM
Vicbuilder's Avatar
It is impossible to "read plugs" and get an accurate determination of what air/fuel your bike is at. A bike may vary from very rich, to very lean, and back to pig rich again all depending on load, speed, rpm, weather, oil temp, etc.
From the looks of your plugs you are not getting the bike up to operating temperature.
If you really want to know what your engine is doing try this: http://www.innovatemotorsports.com/products/MTXL.php
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
post #7 of 23 (permalink) Old 06-28-2014, 08:10 AM Thread Starter
archaicguy's Avatar
Good point....It did idle for a few minutes while I was opening the garage and parking it so no sense inreading it. Got ya
2016 Cross Country
1969 Firebird
post #8 of 23 (permalink) Old 06-28-2014, 08:27 AM
dtmmil's Avatar
if you want a good read you have to do chops like mentioned, get it warmed up good, go out on a long stretch of highway, hold the throttle at the same speed for several miles, pull clutch, hold throttle, kill at same time, coast to a stop, pull plugs , that will give the best read of that throttle position, so do it at a speed you generally run , these bikes are rich on the bottom end and at idle so if you rode it slow to the garage and it idled, they will be black.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #9 of 23 (permalink) Old 06-28-2014, 08:29 AM
BP6666VR's Avatar
That's a plug chop.
That is sooo cool, never knew that ..
I checked my plugs when still stock I just ride for half a day, "not slow but normal hard acceleration for half a day" and when switch off the bike NO idling.... but your way is cool too
my plugs were all grey / white so I decided to put more fuel and air into the motor
Cross Country Tour 2014 [B]
BP6666VR is offline
post #10 of 23 (permalink) Old 06-28-2014, 08:41 AM
vindex1963's Avatar
I know from watching my bike being tuned that a slight change in throttle position and RPM has an effect of fuel mixture not like the old carburetor days.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
