pcv/timing wheel, removing timing with pcv - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 07-03-2014, 02:34 PM Thread Starter
dtmmil's Avatar
Default pcv/timing wheel, removing timing with pcv
how many of you are subtracting timing with your pcv ? is it working correctly? im going back to. 8 on my wheel and plan to take 1-2 degrees out with pcv at about 60% throttle and 2750 rpms. i was getting a ping at that point at 8, so i dropped back to 6, but did notice a drop in low end at 6 vs 8.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #2 of 13 (permalink) Old 07-03-2014, 05:28 PM
How can you judge +8 or +6 by the seat of your pants.
post #3 of 13 (permalink) Old 07-03-2014, 05:32 PM Thread Starter
dtmmil's Avatar
i can feel a loss at low rpms, throttle response, slow turns etc are better at 8 then 6. i ran it at 8 for all last summer and a little this spring, dropped to 6 and could tell right away.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #4 of 13 (permalink) Old 07-03-2014, 07:38 PM
Cheese and crackers. Mine would not even run without pining at 4. I have no idea how you can run 6 or 8. Rylan set it at 2 when he done the cams and tuned it. I still can only run 91 or higher octane.
My ride
2013 Vision Touring. Shelbyville IL
Lloyds 116 big bore
Lloyds timing wheel set at plus 2
Lloyds adjustble intake
Lloyds HP cams
Lloyds quarter turn throttle
PCV 5
Ness Big Honkers
Lloyds Vision intake plate
Lloyds variable clutch
Heads worked over
Built and tuned by Rylan Vos at The Vic Shop
Adel ia.
136HP 139FTLBS
new vic rider is offline
post #5 of 13 (permalink) Old 07-03-2014, 07:44 PM Thread Starter
dtmmil's Avatar
what bike do you have ? and cams may effect it also. the cross bikes seem to be able to take more timing then the others.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #6 of 13 (permalink) Old 07-03-2014, 07:50 PM
I have a Vision with the stage 1 download. I think the stage 1 might add more timing. I thought maybe when the PCV and cams were installed he would raise the timing up to 4 before he tuned it. I told him I ride to Florida twice a year . I already had problems with pining at sea level so he left it at 2 to be safe.
My ride
Lloyds 116 big bore
Lloyds HP cams
PCV 5
Ness Big Honkers
Heads worked over
Adel ia.
136HP 139FTLBS
post #7 of 13 (permalink) Old 07-04-2014, 01:44 PM
MrXC2014's Avatar
I just received my my Lloydz timing wheel and there is a "caution" informing the using to be aware of the total timing when using a PCV & Timing wheel. My question is will this apply to me, I have the Victory stage 1 set-up, victory tri-ovals, filter & map or recalibration ? I know I don't have the pcv but I'm thinking the recal that was done might serve the same purpose as the pcv in regards to the setting?
2014 Victory CC, Two-Tone, VM1-HPT-DR, PC5, ATS+4, Llyodz HI-FLOW A/F, 1/4 Turn Throttle Ring, Tuned by Kyle Crandall of KMC PowerSports, Flashed ECM, 121hp 113tq
Suede Supersteel & Black, Madison, AL
MrXC2014 is offline
post #8 of 13 (permalink) Old 07-04-2014, 02:00 PM Thread Starter
dtmmil's Avatar
put it in at 4 like it comes and go from there, stage one tune may advance the timing so start with 4. the deal with pcv and wheel is the pcv can add or subract timing. so if someone has a pcv and has timing added and adds the wheel they need to be aware of where there timing will be. timing wheel adds timing from idle to full throttle, pcv adds timing from 2500 up.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #9 of 13 (permalink) Old 07-04-2014, 06:17 PM
What do you mean "recall" the motors that Vic had to fix had nothing to do with any fuel or performance.
Stage 1 will add about 2 degrees to timing and make it richer by 1/10 of percent.
So start out at +4 and see what you feel keep track of your mileage using your phone to do the math. The gauge will only give you estimated mileage
post #10 of 13 (permalink) Old 07-04-2014, 10:40 PM
MrXC2014's Avatar
"recall" = recalibration. That's my attempt at using short hand typing.
MrXC2014 is offline
