Quick auto tune question - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 07-05-2014, 11:51 AM Thread Starter
XzombieX66's Avatar
Default Quick auto tune question
When I click get maps and then accept all trims should they apply to the current map and then zero out until i ride again? Reason i ask is cause i accepted trims and noticed the next time i clicked get maps before even riding, the same trim levels were still in place. I thought they were supposed to zero out after you accept all values?
Big Gonzo Mufflers
Lloydz adjustable timing wheel
Ness RAD III Mirrors, Ness Deep cut grips
Vic Hids, Vic Baggers Tarzanz Bars +1 rise +2 pull
Vic Baggers 6.5 degree triple trees
Gorby's Machine 23 inch wheel- Windmill contrast cut,
23 inch wrap around front fender, Whitewall choppers Radio control Bezel and 1.5in Lowering link...
XzombieX66 is offline
post #2 of 10 (permalink) Old 07-05-2014, 02:34 PM
worm5932's Avatar
you have to send the map I believe.
2010 cross roads, Lamborghini Monterey blue
victory fairing with my own audio kit
timing wheel, lloydz filter, atom bomb slip ons
PCV w/ auto tune, VM1 cams, dyno tune by the vic shop, 117HP 119TQ
worm5932 is offline
post #3 of 10 (permalink) Old 07-06-2014, 10:09 AM
No. Do not zero them out otherwise you will undo everything you just did. They will change again up to 20% unless you changed this value in the software. Just save the existing map in case you want to back to it then accept the trims and ride.
post #4 of 10 (permalink) Old 07-06-2014, 10:37 AM
dtmmil's Avatar
when you accept them it asks if you want to put them to the map it zeros out the trims though doesnt it?
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #5 of 10 (permalink) Old 07-06-2014, 10:48 AM
Ya know... I think you are right about that. It has been a while since I messed with it.
post #6 of 10 (permalink) Old 07-06-2014, 09:16 PM
ChiTownVegas's Avatar
Plug in autotune... hit "accept all trims"... unplug autotune.
It's really that simple.
2012 Vegas 8 Ball
LLoydz VM1 drop in cams
LLoydz Adjustable Timing Wheel
LLoydz 1/4 turn throttle ring
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
Pirelli Night Dragon rubber
ChiTownVegas is offline
post #7 of 10 (permalink) Old 07-07-2014, 11:06 AM Thread Starter
XzombieX66's Avatar
see i accept all trims and then hit send map, but when i go back to get map it still shows values in the trim tables. I thought they were supposed to zero out until your next ride, and then you would see values where it made trim adjustments?
Big Gonzo Mufflers
post #8 of 10 (permalink) Old 07-07-2014, 12:25 PM
dtmmil's Avatar
after you accept trims does it ask you to apply trims?
when i connect mine i dont click get map, i open the pcv software then plug my cord in, then my map is already there, the screen is blank till i click on trims or whatever. i look at my trims then accept, then click to apply trims when it asks.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #9 of 10 (permalink) Old 07-07-2014, 12:43 PM
worm5932's Avatar
Another thought, I called tech support and they walked me through quite a few things. Good support in my opinion.
worm5932 is offline
post #10 of 10 (permalink) Old 07-18-2014, 09:51 PM
What Dtmmil said.
2014 XCT15 th Anniversary Limited #077 D&D's
Midnight Cherry 2009 Vision Victory Stage 1 mufflers traded off
(XCT totoled on dragon tail 8-10-14)
Black 2012 Cross Country Tour that now has 14000 miles. 195/55-R16 Rear, Stone 709 on front.
PCV, Autotune, D&D's /Lloydz's air filter.
strip removed. Added CB 7/27/14 it works! LOL
2005 Yellow Goldwing Motor Trike Sold.
93 GL1500 red
Moto Guzzi's for years 71 750 Ambassador fairing and bags. 79 1000 G5 with fairing, saddle bags and trunk.
GrogAV is offline
