Victory Throttle Body Cleaning - Victory Forums - Victory Motorcycle Forum
post #1 of 17 (permalink) Old 07-06-2014, 02:49 AM Thread Starter
BP6666VR's Avatar
Default Victory Throttle Body Cleaning
Did anybody do this already ;
Victory Throttle Body Cleaning = http://www.thebikersgarage.com/victo...body-cleaning/
When i installed my TT and filters it looked very dirty, and now i read this and was wondering if some of you guys did this already?
Cross Country Tour 2014 [B]
BP6666VR is offline
post #2 of 17 (permalink) Old 07-06-2014, 03:04 AM
You don't need to clean the newer throttle bodies. I think it's 2008-up they changed design so it's no longer required.
2011 vegas 8ball PCV, swept pipes rpw modified baffles, llyodz vm1-dr cam, ats +4, 1/4 throttle, ud pulley and ness intake.
KMC tuned 114hp/125ft/lbs
shanko is offline
post #3 of 17 (permalink) Old 07-06-2014, 05:59 AM
Motorbikerx's Avatar
I cleaned it on my 2010 when I had the old airbox cut off.
There was a bit of darkening here and there that I removed with carby cleaner and a clean rag.
It was squeaky clean then...seems silly not to clean it up while its pulled down.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 17 (permalink) Old 07-06-2014, 06:00 AM
I presume you gave it a clean while you had it apart?
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #5 of 17 (permalink) Old 07-06-2014, 12:16 PM
99 to 2007 you should do it maybe once every other year. Early models had blow by tube going to filter now it goes to frame and discharges
http://www.youtube.com/watch?v=QOeH1UgzhQc#t=20
post #6 of 17 (permalink) Old 07-06-2014, 12:53 PM
spikey2's Avatar
Default admit it, you are bored!
yes?
'13 Hardball
Vespa GTS300
MV Brutale 1078RR
spikey2 is offline
post #7 of 17 (permalink) Old 07-07-2014, 12:49 AM
Oldman47's Avatar
Look at VisionJohnny's post. That WD video tells you all about how to clean a throttle body in the older bikes.
Oldman47 is offline
post #8 of 17 (permalink) Old 07-07-2014, 01:46 AM Thread Starter
BP6666VR's Avatar
When I installed the TT then I only cleaned the throttle-body not the connecting tubed that were dirty, as the valves are down there and did not want any dust or rag piece falling in there.....
only 5 K on the counter I did not see the point of cleaning "inside" it but I would imagine after a few years I will when I take off the tank for some reason.
BP6666VR is offline
post #9 of 17 (permalink) Old 07-07-2014, 07:54 AM
Cleaning the throttle body is fine BP6666VR, I wouldn't go any deeper into the inlet manifold either, just keep running on good clean fuel of the required octane, now you've got the TTI the only foreseeable reason to remove your tank is for fuel filter replacement a long way down the track at 30,000 miles I think they recommend?
sheeet Im only 7000 miles off that now!
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #10 of 17 (permalink) Old 07-07-2014, 08:42 AM Thread Starter
BP6666VR's Avatar
That is what worries me the most "Motorbikerx" the fuel we are having is terrible.... I ran old landcruizers here on the island for mud-offroading and I had to change filters all the time, about 3 inline as 1 filter was not enough to remove dirt and water, ps 1 day in the jungle was about 80 Liters of fuel
For the Victory's we buy the most expensive fuel available and still I wonder if the filter would be blocked sooner then later.... I was even looking at JP websites for the future to remove the VIC-filter and just run external filters inline so i can see the dirt and or water that is captured into the glass inline fuel filters ...... any better ideas of bikers out there?? so the recommended changing of filters made me laugh what I read the manual purchasing the bike.
Not even to mention Octane... and our Victory's ride average on 1 liter = 14 Km so guessing the octane is not that high if even any available in the petrol we run?
BP6666VR is offline
