Throttle body and Intake cleaning - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 01-13-2012, 04:13 PM Thread Starter
Tims_04V92TC's Avatar
Default Throttle body and Intake cleaning
While replacing my stock intake on my 04 V92, was completly prepared to commence cleaning the TB and noticed when I opened the butterflys a significant amount of build up on both intakes below the TB's.
If this was my Ford, I would start it and begin shooting gumout right down the intake washing it through the system while running.
I am trying to be a better garage mech with my VIC and see if there is a better way to remove this build up without removing the TB's and getting in there to clean it with an appropiate cleaner and rag. Just want to ensure I am taking care of my pride and joy correctly.
As always, thanks for the input!
Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #2 of 3 (permalink) Old 01-13-2012, 06:52 PM
browneye's Avatar
Clean 1 day let it evaporate overnight and it should be ok. to my knowledge it evaporates in about 30 minutes but it would probably take a bit longer inside the intake.
2008 Vegas Premiumthumb up
1978 Harley FXE [email protected]$TERD Shovel:mad:
browneye is offline
post #3 of 3 (permalink) Old 01-14-2012, 08:55 AM
Tarzan's Avatar
I use a long screw driver with a clean cloth.Spray(soak) the cloth with cleaner then push a big wad past the throttle bodies. I use a long rag so I can hang on to one end and pull it back out. You can rig the throttle bodies open while doing this. The intake runners clean up pretty easy. Obviously you want to be real careful not to scratch the butterflies or throat of the throttle bodies. Just wrap the rag around the screw driver or what ever you use. Then pull out the screw driver.With the rag down in there, you can use a tooth brush and scrub around them in there too.That is the way I do it anyway. Then just pull your rag out. I use two rags.Get the bulk of it the first time. Then use a clean section of rag and do it again. They look like new when I'm done,and I don't end up with anything going into the cylinders.
'14 Ness XC
Tarzan is offline
