Low Speed Lugging? - Victory Forums - Victory Motorcycle Forum
post #1 of 53 (permalink) Old 07-19-2014, 04:58 PM Thread Starter
Big Tav's Avatar
Default Low Speed Lugging?
Hi, it might be my imagination but my bike seems to lug a little bit now at low rpm. Could that be because of the Timing Wheel? it is only minor but I find myself using the clutch a little more to smooth things out. I have only done a few hundred miles on my bike so I could be just imagining it.
Any thoughts?
2015 Highball Black - Mods being done now!
Suzuki M109R L0 - Sold
BMW K1200R - Sold
Suzuki TL1000R - Sold
2014 Victory Hammer S - Sold
2012 Victory Highball - Swept Pipes, RPW Baffles Stage 1, 02's Removed, Lloydz Timing Wheel 4+, 1/4 Turn Throttle Ring, Mini Bullitt LED Indictors, Kewl Metal Brackets, Arlen Ness Pegs & Grips, Arlen Ness Cam Cover, K&P Oil Filter, Magnetic Sump Plug, Rear Axle Covers, Black Engine Bolt Kit. - Now Sold :(
Big Tav is offline
post #2 of 53 (permalink) Old 07-19-2014, 05:17 PM
Tims_04V92TC's Avatar
Any thoughts?
Gear, speed and what rpm is the problem at. 2000-2500 about as low as you want to get and you shouldn't need clutch to smooth anything. The recommended shifT points in the owners manual should give you a solid starting point til you get used to the bike. If it sounds like a HD at low speed your probably lugging it. Lol
Congrats and safe ridin
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #3 of 53 (permalink) Old 07-20-2014, 12:27 AM
ford4x4's Avatar
mine seems to be the same. it always has a low rpm but after timing wheel seems to be worse.
ford4x4 is offline
post #4 of 53 (permalink) Old 07-20-2014, 02:24 AM
Motorbikerx's Avatar
should be better with the wheel, try some different settings, mines fine at 4 adv but all motors and states of breathing respond different to different advance
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #5 of 53 (permalink) Old 07-20-2014, 11:54 AM
navycraig's Avatar
The throttle is there for a reason. Use it...or down shift.
God Bless America
U.S. Navy Retired
2012 Victory Crossroads Classic L.E. (#258)
PC V and Dyno tuned by Kyle of KMC
Lloydz High Flow Filter
Lloydz Timing Wheel
Lloydz Drop In Cams
Lloydz 1/4 Turn Throttle
Crossroads HID high/low lights
Making 113 HP and 115 TQ
navycraig is offline
post #6 of 53 (permalink) Old 07-20-2014, 12:38 PM
half_crazy's Avatar
My bike feels like it's lugging when I give it full throttle at 1250 rpm in 5th. What do you think the problem could be? Do you think the timing wheel would help?
2006 Victory Kingpin
half_crazy is online now
post #7 of 53 (permalink) Old 07-20-2014, 01:02 PM Thread Starter
Big Tav's Avatar
Thanks for that. I'm talking about in 1st & 2nd gear under 2,000 rpm like when in traffic or car parks. I don't remember it being like that before the timing wheel.
BMW K1200R - Sold
Big Tav is offline
post #8 of 53 (permalink) Old 07-20-2014, 02:07 PM
navycraig's Avatar
NO! You obviously need riding lessons. Let me know if there is anything I can do to help.
God Bless America
U.S. Navy Retired
Lloydz Timing Wheel
Lloydz Drop In Cams
post #9 of 53 (permalink) Old 07-20-2014, 02:11 PM
navycraig's Avatar
I wish I could help Tav. I'm at 950 to 1000 at idle. Leaving a light or whatever other conditions, I won't go to 2nd until 2500-2800. If traffic is putzing along so slow that I'm below 2000 in 1st, I'm too pizzed to worry about it anyway.
God Bless America
U.S. Navy Retired
Lloydz Timing Wheel
Lloydz Drop In Cams
post #10 of 53 (permalink) Old 07-20-2014, 02:54 PM Thread Starter
Big Tav's Avatar
All I'm trying to say is that I'm an experienced rider so it's not that I can't ride. I have just noticed that I have just gotten my bike back after the Timing Wheel and the baffles changed and I am noticingbi have to slip the clutch a bit more than what I should to stop it from lugging in 1st under 2000. I don't think I noticed that before. Maybe the fueling/map from stage 1 is not quite keeping up now and it's time for a new intake and PCV?
BMW K1200R - Sold
Big Tav is offline
