Tires are done. Finally. - Victory Forums - Victory Motorcycle Forum
post #1 of 26 (permalink) Old 07-19-2014, 09:17 PM Thread Starter
Default Tires are done. Finally.
I started at 1:30 and got done at 9:00. It was a PAIN IN THE ASS. I can't believe how hard it was to break the beads on these things. I bought a cheap bead breaker and ended up bending it. Ran to Harbor Freight to get a better one.
I hated the way the OEM Dunlop E3s felt. Horrible on tar snakes. Bought a set of Bridgestone tires, the same ones for the GoldWing - G704 and G709
Removal of the front wheel was cake. Removing the tire from the wheel was something else entirely. Just when I thought that bead wouldn't break, it did.
The rear, however, was unbelievable. I pulled muscles I didn't think I had. I gave up 3 times. Just when I was going to give up for good, it went.
Another matter was putting the rear wheel back on. Ended up taking the brake pads out to do it.
All in all, I have new shoes on the bike. And I did it myself. Now, I hope they last 40,000 miles :-)
post #2 of 26 (permalink) Old 07-19-2014, 10:01 PM
Now you can say you're retired.
At my age, I'm going to look for the least strenuous ways to do these sorts of things. To remove the rear wheel (bike on a lift) I placed a floor jack under the tire and applied just enough pressure to take the strain off the shock bolts. With those bolts removed, the jack was lowered until the swingarm stopped. Then applied pressure to take strain off the axle. Pulled the axle and lowered the wheel on the jack. To re-install the wheel the process is reversed. It helps to have someone operating the jack while you are under the bike. Pretty Wife was my helper with the jack.
post #3 of 26 (permalink) Old 07-19-2014, 10:04 PM
fordwrench's Avatar
I use 2 heavy duty c clamps to break the beads loose, Getting the tire back on the last bead is another issue.
15 Gunner
83 CB1100f
09 KLX250S
76 CB750K6
73 Kawasaki H1 Triple
78 KX250A94 KX250
fordwrench is offline
post #4 of 26 (permalink) Old 07-19-2014, 10:18 PM Thread Starter
I wanted to do that. However, I could not budge the shock bolts. So I ended taking off the left muffler.
Sent from Motorcycle.com App
post #5 of 26 (permalink) Old 07-19-2014, 10:19 PM Thread Starter
Indeed.
post #6 of 26 (permalink) Old 07-19-2014, 10:23 PM
When you're 77 years old, you'll be able to do it w/o removing a muffler, young 'un.
post #7 of 26 (permalink) Old 07-19-2014, 10:56 PM
Lostintexas's Avatar
E3's are a soandso, Stones aren't a lot better when it comes to replacing them on a rim.
Remember, you just lost about 170 pounds of rear tire load rating (ever wonder why wings eat tires). This may not make any difference if you and your pillion, if you ride with one, are light.
Side note: Stones were my favorite on the Wing, well, next to the Darkside tire.
Cheers
I ride with the Force.
Lostintexas is offline
post #8 of 26 (permalink) Old 07-20-2014, 05:54 AM Thread Starter
Interesting. No, we are far from light. But, now that I know how to change the tire, nothing stopping me from trying the dark side now
post #9 of 26 (permalink) Old 07-20-2014, 11:52 AM
Interesting. No, we are far from light. But, now that I know how to change the tire, nothing stopping me from trying the dark side now [/color]
Please Broggy don't do it, don't drink the Kool-Aid and put down that apple.
post #10 of 26 (permalink) Old 07-20-2014, 12:44 PM
i like doing my own work but NOT tire changes! i remove then + let my buddy a former duc dealer with a machine mount + balance them $50 + 30 minutes or less including conversation!! i am more concerned about what i could do to my rims.
rodhotter is offline
