Wiring Help... - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 01-21-2012, 06:19 PM Thread Starter
Default Wiring Help...
I have a 2008 Jackpot.. Today I installed a side mount license bracket with tail light.. When I wired it up.. I did a test I connected it to the main wire harness to the tail light.. Everything worked, put when I plug in the tail light plug which I tap into.. Only the tail light comes on, not the light on the plate frame..
Only 2 wires...
ucadam is offline
post #2 of 9 (permalink) Old 01-21-2012, 06:28 PM
Tarzan's Avatar
How is the license plate frame grounded?
'14 Ness XC
Tarzan is offline
post #3 of 9 (permalink) Old 01-21-2012, 06:37 PM Thread Starter
Default wiring
Good question.. Their were 3 wires a brown one.. but thats for the lic. plate white lights.. Im not using that..
ucadam is offline
post #4 of 9 (permalink) Old 01-21-2012, 06:46 PM
CrossRoads's Avatar
Most likely the license platewires came lose during the install. Check wires and connections.
CrossRoads is offline
post #5 of 9 (permalink) Old 01-21-2012, 06:50 PM
saddlebag's Avatar
Only 2 wires...
Use a meter and check the tail light plug for power. If it's not there, trace the wiring back to the main harness to see if it's actually connected.
2011 Cross Roads
saddlebag is offline
post #6 of 9 (permalink) Old 01-21-2012, 06:51 PM Thread Starter
Default Wiring
I tried that.. did it all again.. same thing.. Tail light on bike works, but not on plate.. If I un-plug the tail light plug, the bike tail light will go out... BUT the Lic. plate light will work..
Just cant seem to get them both on when connected..
ucadam is offline
post #7 of 9 (permalink) Old 01-21-2012, 06:57 PM
use the brown wire from the plate lights and it should work.
2007 VEGAS ( BIG BALLS )
www.houseofthunderusa.com
DAREDEVIL is offline
post #8 of 9 (permalink) Old 01-21-2012, 07:00 PM Thread Starter
Default wiring
I will give it a try... Just have to track it down.. since I put heat shrink to it all...
ucadam is offline
post #9 of 9 (permalink) Old 01-22-2012, 06:53 PM Thread Starter
Default wiring
Well I give up.. I have wired all ways.. Just gonna take it to my dealer, let them figure it out.. Plus they have to install a Load Equalizer for my front & rear MBW LED's
ucadam is offline
