Lyndall or EBC brake pads? - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 07-26-2014, 01:44 PM Thread Starter
toejam's Avatar
Default Lyndall or EBC brake pads?
Looking to replace the brake pads and wondered what the masses think of the Lyndall & EBC brake pads.
As far as Lyndall, I'm gravitating towards the Gold Plus 7175 for the fronts, and the Gold Plus 7176 for the rear I like the dustless idea. Just haven't seen that much about EBC and not sure what model numbers to look at that would be a close comparison to the LRB Gold Plus's. I would appreciate feedback on what to look for in the EBC line, and if there are reasons to, or reasons not to go with one versus the other. Thanks!
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #2 of 14 (permalink) Old 07-26-2014, 04:36 PM
here there is 191 post on the pads
https://www.victoryforums.com/showthr...EBC+brake+pads
post #3 of 14 (permalink) Old 07-28-2014, 06:52 AM
Squatch's Avatar
TJ,
Went from OEm to Lyndall to EBC. Lyndall's preformed better than stock and EBC better than Lyndals.
Cheers
Squatch
USN/USCG Vet
2013 Cross Country Tour
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
D&D wrapped/RPW baffles
Touring Cams
124 hp/119#ft
A country that forgets it's defenders, will itself soon be forgotten
Squatch is offline
post #4 of 14 (permalink) Old 07-28-2014, 07:02 AM
saddlebag's Avatar
http://buywitchdoctors.com/c/293/vic...l-motorcycles/
2011 Cross Roads
saddlebag is offline
post #5 of 14 (permalink) Old 07-28-2014, 07:04 AM
half_crazy's Avatar
EBC HH on mine.
2006 Victory Kingpin
half_crazy is offline
post #6 of 14 (permalink) Old 07-29-2014, 02:58 PM Thread Starter
toejam's Avatar
While I welcomed replies, I figured I could count on some thing that actually pointed me to specific part numbers which is part of what I requested in the comparison of brands. That link led me to 15 pages of mostly kids pissing in each others wheaties with regards to Witchdoctors. At least you could have checked your source, but thanks for trying. I ended up going with the EBC HH sintered pads. Case Closed......
BadBoy Horn, PCV
2006 Hammer - Gone
toejam is offline
post #7 of 14 (permalink) Old 07-29-2014, 04:13 PM
Can anyone recommend any low dust pads?
2013 Victory Hammer 8-Ball
mobgma is offline
post #8 of 14 (permalink) Old 07-30-2014, 04:13 AM
captainbrent's Avatar
Lyndall Gold+ and no squeaking noises!
'13 Sunset Red Judge
captainbrent is offline
post #9 of 14 (permalink) Old 07-30-2014, 04:52 AM
Pheonix's Avatar
To answer the poster's original question....
Lyndall if you can afford them. EBC if you can't afford the Lyndalls. Either way it's an improvement over OEM's.
2011 Kingpin - Scarlett
Stage I Pipes with Thunder Monsters & NO Catcons
Ness Laydown Plate Holder with Custom Dynamics LED Plate Frame
Custom Ness Engine Covers
V92C Floorboards with NON-LOW Mounts
Ness Ram-Air
PC-V
Lloydz Timing Wheel
Dyno Tuned by 804 Motor Sports
97.26 HP / 110.42 # for now...
Pheonix is offline
post #10 of 14 (permalink) Old 08-07-2014, 04:17 AM
Motorbikerx's Avatar
Just fitted the LYNDAL's rear pads to my Vegas today, was easy thanks to VisionJohnnys posting of the Witchdoctors vid (thx)
went for a 60 mile ride to try em out....silly me pulled over and grabbed the rear rotor to see how hot it was after a couple of stops...it was fkn HOT!.... cooled down with five mins riding so no caliper problems.
Works well...installed at 39,850 kms
the pads that came out had NISSIN on the back of them...would they be the originals???
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
