Gear noise 6th sixth gear? - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 07-27-2014, 07:34 AM Thread Starter
bsbabcock's Avatar
Default Gear noise 6th sixth gear?
Anyone notice 6th gear having a bit of noise compared to the others? Like a groan or a low-pitch whine like gear noise. Not very loud but noticeable.
It's shifting ok and acting normal I've just noticed this as I've been running a windshield and can hear the bike more so thought I'd ask.
Thought maybe because 6th is an overdrive. I dunno.
2013 Hard-Ball - Lloydz VM1-DR cams, air filter, timing wheel, PCV, properly tuned at KMC
Master, Biltmore Lodge #446, AF&AM
bsbabcock is offline
post #2 of 19 (permalink) Old 07-27-2014, 08:29 AM
I'm guessing it's belt noise due to the teeth. It's traveling quite fast compared to the lower gears.
Sent from Motorcycle.com App
post #3 of 19 (permalink) Old 07-27-2014, 08:40 AM
Pauljp's Avatar
Yup, I can always tell when I'm in 6th gear. Sounds totally different than all the others.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #4 of 19 (permalink) Old 07-27-2014, 09:36 AM Thread Starter
bsbabcock's Avatar
It's definitely the tranny and not the belt. You can hear it if going 60 in 5th or 6th at same belt speed.
Due to being an overdrive maybe?
post #5 of 19 (permalink) Old 07-27-2014, 09:58 AM
robvision's Avatar
Yes I hear it to. But 3rd is louder and 4th now sounds like a rock crusher. 5th is very quiet.
It seems the tranny is getting very noisy as the miles climb. I always change my oil well before the recommended interval.
I am at 35,000 km now and I can't see this tranny going the distance unless it just keeps getting louder.
I am getting very concerned how fast it seems to be wearing out....
What milage you guys at?
I was just going to post a thread on this and see if any of the high milage guys are getting tranny noise...
Rob
2010 V Star 650 Custom (Wife's)
2013 XCT 2013 Suzuki KQ750 AXI Power Steerring
Victory Sport Touring Flag Ship
Lloydz Idle Air Valve
Lloydz PTW
60,000 km
Rear Rack
Passenger Grab Handles
Modified Heel Shifter
HID Low
Oil Temp Gauge
Ride-On TPS
Modified Stock Pipes by Thrush
K&N air filter
G-man Bully FI Controller
Heat Troller
LED Driving lights
PCV with AutoTune
robvision is offline
post #6 of 19 (permalink) Old 07-27-2014, 01:37 PM Thread Starter
bsbabcock's Avatar
Fairly new bike here. 1700 miles.
post #7 of 19 (permalink) Old 07-27-2014, 05:39 PM
robvision's Avatar
I think you need to check your belt tension and alignment ...
Keep an ear open for gear noise in 4th. It will get louder as the miles rack up.
Rob
Lloydz PTW
60,000 km
Rear Rack
HID Low
Oil Temp Gauge
Ride-On TPS
K&N air filter
Heat Troller
LED Driving lights
PCV with AutoTune
post #8 of 19 (permalink) Old 07-27-2014, 05:40 PM
4 inch pistons's Avatar
Almost 9,000 miles and quiet as can be on a 2012 model except for a squekey belt.
[SIGPIC]
[/SIGPIC]
"The Road Goes on Forever and the Party Never Ends"-Robert Earl Keen
4 inch pistons is offline
post #9 of 19 (permalink) Old 07-27-2014, 05:50 PM
robvision's Avatar
Last year I was at wits end with my squeaky belt so over the winter I reversed it.... Yes put it on backwards.
This year no squeak .....
I have run the belt to tight then to loose. Ran it to the inside then the outside of the pulley...... No squeak ....
Some on here say the belt will break but I couldn't take any more squeak...
As far as tranny noise.... Roll into it in 4th and tell me if you hear metallic gear sounds.
Rob
Lloydz PTW
60,000 km
Rear Rack
HID Low
Oil Temp Gauge
Ride-On TPS
K&N air filter
Heat Troller
LED Driving lights
PCV with AutoTune
post #10 of 19 (permalink) Old 07-27-2014, 06:57 PM
philmonger's Avatar
If you can hear it in 5th & 6th at the same speed, it seems to rule out the tranny and point to the belt? Am I missing something? I hear the noise on my bike too. I am quite sure it is the belt. I'm pretty sure I can fix it with a louder exhaust....
2011 XR Midnight Cherry, Hard Bags, Vic htd grips & seat, Vic medium Windshield, unlocked speedo, Lloydz Air filter, VFC III, Lloydz ATS +4, Vance & Hines slip ons
1993 Vulcan 1500 (sold)
1981 Yamaha Seca 750 (ridden into oblivion)
1977 Honda 550 (sold)
philmonger is offline
