Lowering issues - Victory Forums - Victory Motorcycle Forum
post #1 of 22 (permalink) Old 08-01-2014, 01:44 PM Thread Starter
miller_david1's Avatar
Default Lowering issues
So I attempted to lower my XC 1" with the witchdoctor lowering link. As I was trying to loosen the nuts for the shock and the lowering link; the nut on the lowering link began to strip, and I have the feeling that it's going to continue.
Any ideas on how to remove the nut without it stripping further, or other ideas how to loosen things up?
miller_david1 is offline
post #2 of 22 (permalink) Old 08-01-2014, 09:21 PM Thread Starter
Dang, really hoping for ideas from guys that have done the job and came across the similar issue; otherwise I know it's the same as any other tight nut, but this thing is ridiculously tight. Extremely torqued from the factory.
post #3 of 22 (permalink) Old 08-01-2014, 10:19 PM
cut it off grind it off
post #4 of 22 (permalink) Old 08-01-2014, 11:57 PM Thread Starter
Well that was what I was thinking, just looking for ideas that may not require that, but if it comes to that then that works for me. Thanks
post #5 of 22 (permalink) Old 08-02-2014, 04:38 AM
captainbrent's Avatar
Maybe over torqued and/or maybe some high strength thread lock on it? Can you try applying some heat to the nut? Also, use a 6 point socket or box end wrench as it is almost impossible to "strip" a nut with 6 points so you can apply more pressure to break it free! Don't attempt it using a 12 point socket or an open end wrench.
Cheers
'13 Sunset Red Judge
captainbrent is offline
post #6 of 22 (permalink) Old 08-02-2014, 03:33 PM
rhino 2's Avatar
Like posted above.. More than likely Tread-Lock.. With a small propane torch heat the head of the bolt.. Some tread-lock needs heat to loosen.. Good luck..
Been there broke that..
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #7 of 22 (permalink) Old 08-02-2014, 03:46 PM Thread Starter
Thanks guys, that was my only other thought; I'll try that before anything else.
post #8 of 22 (permalink) Old 08-02-2014, 06:18 PM
4 inch pistons's Avatar
Getting those nuts off was the hardest part of the job in my case. Breaker bar (AKA pull handle) with a piece of pipe to extend the handle if I remember correctly. The left side was much easier than the right side.
[SIGPIC]
[/SIGPIC]
"The Road Goes on Forever and the Party Never Ends"-Robert Earl Keen
4 inch pistons is offline
post #9 of 22 (permalink) Old 08-11-2014, 08:47 AM Thread Starter
Well I finally got a chance to get back at the nut (been working and riding it too much); I took a torch and heated it, the thread lock bubbled out; however, the damn thing still wouldn't budge and continued to slip. My final option might be to cut the whole dang nut off.
But I think I'll just let it be for now until the riding season is over (roads full of snow). I was just looking for a little more stability on uneven roads/stops and while trying to back up on slight down hill parking.
post #10 of 22 (permalink) Old 08-11-2014, 09:44 AM
dtmmil's Avatar
are you using the right sized wrench ? its a 15mm, i use 2 wrenches to break them loose.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
