can I pull codes without going to the dealer? - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 08-04-2014, 12:04 PM Thread Starter
Jackpot!'s Avatar
Default can I pull codes without going to the dealer?
2010 Jackpot, mods in Sig. Having the occasional engine light flash at me as well as a stumble off idle. Y'day afternoon it developed a very unstable idle, flashed the light and quit. I turned the switch off and back on, restarted and it was fine. How can I check my codes?
2010 Victory Jackpot, Elkton, Va in the Shenandoah Valley. Tequila gold, Ness Flybars, Victory HID conversion, Lloydz TTI, VM1 cams,PCV based by Rylan, RPW Bad Boy, Lloydz ATS, Lloydz IAV, K&P filter. Goal=106 @130hp
Jackpot! is offline
post #2 of 10 (permalink) Old 08-04-2014, 12:35 PM
BP6666VR's Avatar
what codes mate ?????
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 10 (permalink) Old 08-04-2014, 12:45 PM
I'm guessing engine codes/diagnostic codes.
post #4 of 10 (permalink) Old 08-04-2014, 01:22 PM
BP6666VR's Avatar
I am happy to subscribe and see what truth comes out as i have no idea ????
BP6666VR is offline
post #5 of 10 (permalink) Old 08-04-2014, 02:54 PM
ptc
ptc's Avatar
read your owners manual or get one online and find out how to read your error codes from your speedo display. Then call your VIC dealer and give them the info and they will tell you whats up.
If your speedo doesnt have this capability then you'll have to take it in and have them hook it up to a diagnostic reader.
2011 Custom "Hammered XR"
http://streetbikeusa.blogspot.com/
BBob- "We all share the same wind regardless of the t-shirts we wear"
ptc is offline
post #6 of 10 (permalink) Old 08-04-2014, 03:03 PM Thread Starter
Jackpot!'s Avatar
Yes I meant engine codes, sorry. No,I don't have the fancy newer speedo, Damn.
Jackpot! is offline
post #7 of 10 (permalink) Old 08-04-2014, 05:18 PM
Motorbikerx's Avatar
Suggest you clean. Tighten and grease battery terminals, also theres a temp sender on rear of front cylinder that can have the snap on connector di electric greased.
Actually any connector you can access would probably benefit from disconnection and cleaning and di electric grease before resnapping on.
Plug the bike in at your nearest friendly dealer if possible and all will be revealed.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 10 (permalink) Old 08-04-2014, 05:24 PM
"flashed the light" I don't understand.
Use a wrench and check battery bolts.
Are you blipping the throttle.
post #9 of 10 (permalink) Old 08-04-2014, 07:12 PM Thread Starter
Jackpot!'s Avatar
I have removed and cleaned battery terminals, cable ends etc and reinstalled with dielectric grease. Last week I did find a loose negative cable on the battery, thus the reason for cleaning and tightening cables. I checked them again this eve and they are good and tight. I also checked battery voltage with the bike running at idle and with a light rev. It was consistently 14.39-14.40 & would drop sharply with a blip of throttle but quickly return to 14.4. Also, no check engine light this evening either. One other thing I noticed this eve was that I think I may have a bit of a misfire. I have a stumble through the exhaust on the rear cylinder. I checked the wires and I have spark bleeding through the spark plug wire and arching against the rocker box. Always something I guess.
Jackpot! is offline
post #10 of 10 (permalink) Old 08-04-2014, 07:20 PM Thread Starter
Jackpot!'s Avatar
Already done part one, also, yes it will stumble with a blip of the throttle. I'm wondering if some of this doesn't have to do with a bad plug wire. I've contacted Witchdocters about the issue. We'll see what happens I guess.
Jackpot! is offline
