Incredibly loud gear whine - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 08-04-2014, 06:42 PM Thread Starter
rumblebox's Avatar
Default Incredibly loud gear whine
So after i lowered the bike earlier this year, i started to notice a gear whine type noise when i would hit a bump and load the suspension. I didn't think anything of it until recently when i changed my tire and it got worse. I thought it had to do with bad wheel alignment or the new oil i started using, until i removed the front pulley cover and looked more closely. It was the top of the belt rubbing against the front cover. So I'm going to grind off part of the cover where it rubs.
2007 Hammer, lowered, Bassani 2:1(updated), torque tubes, Dobeck AFR+.
2000 Firebird Formula, 6.0L, LS3 heads, etc, etc, etc, - SOLD
HM3(FMF) - 3/7 Lima Co. 2010 Helmand, Afghanistan
rumblebox is offline
post #2 of 5 (permalink) Old 08-04-2014, 09:38 PM
DillPickle311's Avatar
Hey! Make sure that bolt on pulley is torqued correctly while you are there.
DillPickle311 is offline
post #3 of 5 (permalink) Old 08-04-2014, 09:42 PM Thread Starter
rumblebox's Avatar
If it makes any difference, the belt was all the way to the outside of the pulley when i removed the cover.
post #4 of 5 (permalink) Old 08-05-2014, 12:40 PM
look at the outer cover you might need to grind it to
post #5 of 5 (permalink) Old 08-05-2014, 08:39 PM Thread Starter
rumblebox's Avatar
That's the part I'm talking about.
