Lighted License Plate frame where to hook it to - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 02-06-2012, 06:34 PM Thread Starter
Default Lighted License Plate frame where to hook it to
I have just inalled a lighted license plate frame, on a 2008 Jackpot Premium with positive and negative wires... Where should i hook this to, since I can't directly wire it to the battery...
Dont need it on 24/7
Regards
ucadam is offline
post #2 of 18 (permalink) Old 02-06-2012, 06:37 PM
CrossRoads's Avatar
Red face
Originally Posted by ucadam View Post
I have just inalled a lighted license plate frame, with positive and negative wires... Where should i hook this to, since I can directly wire it to the battery...
Regards
Well, now that you've made this interesting by not telling us what you ride, we're going to all give you different directions on where to connect it. Out of which, most will not apply to your model.
By the way, connecting it directly to the battery is a good idea only if you want the plate to be illuminated 24/7, even when the bike's napping in the garage.
CrossRoads is offline
post #3 of 18 (permalink) Old 02-06-2012, 06:41 PM Thread Starter
Default lighting
I fixed it.. I meant to say cant directly wire it to the battery..
Thanks
ucadam is offline
post #4 of 18 (permalink) Old 02-06-2012, 06:50 PM
CrossRoads's Avatar
Thanks
Cool. Now, what bike are we talking about? Year/Model?
post #5 of 18 (permalink) Old 02-06-2012, 06:53 PM Thread Starter
Default lighting
It's a 2008 Jackpot Premium...
ucadam is offline
post #6 of 18 (permalink) Old 02-06-2012, 07:03 PM
CrossRoads's Avatar
Try to locate a wire running from under the seat area towards the tail light. It should be white or a different color (blue, green, purple) wire. That is the positive 12 volt wire. You want the plate LEDs getting their juice from that. FYI, there is another wire for the brake light - you do not want that one for obvious reasons.
The plate's LEDs should also be grounded, anywhere on the bike where there's a good ground. You can touch various places on the chassis with the black wire of the license plate LEDs to see if it's a good ground or not.
post #7 of 18 (permalink) Old 02-06-2012, 07:06 PM Thread Starter
Default lighting
Sounds good I will try to locate that wire tomarrow...
Thanks
ucadam is offline
post #8 of 18 (permalink) Old 02-06-2012, 09:27 PM Thread Starter
Default Lighting
Just wondering if I could use the pig tail wires that were connected to the plate light on the OEM bracket.. the wires are Purle & Black..
If this is possible would I still need to ground it to the frame of the bike..
ucadam is offline
post #9 of 18 (permalink) Old 02-06-2012, 10:15 PM
the purple is 12V and the black is your ground !
2007 VEGAS ( BIG BALLS )
www.houseofthunderusa.com
DAREDEVIL is offline
post #10 of 18 (permalink) Old 02-06-2012, 10:36 PM
CrossRoads's Avatar
Just wondering if I could use the pig tail wires that were connected to the plate light on the OEM bracket...
The OEM plate is lit by a 5 watt bulb - chances are your new LED plate light uses a lot less electrical power. This wouldn't normally be a problem, but the lower consumption could convince the relay that the bulb is actually out, and it will not supply it with power. If that's the case, abandon the OEM license plate connection and tap into tail light for the 12volt connection, and ground to the chassis.
