False Neutral - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 08-06-2014, 03:55 PM Thread Starter
Term's Avatar
Default False Neutral
I did a search and found one thread of a guy on a Hammer that had this happen. It caused him to dump it because he tried to start it when it indicated it was in neutral but it wasn't. I am seeing this on my Vision. It has done it 3 or 4 times now. I am not sure if it would try to start or not, haven't had that happen yet.
Today as I was leaving a parking lot I realized I had not tuned on my Sena. So I stopped the bike put it in neutral, both indicators showed it was in Neutral had the little N and the big N, but when I let out the clutch it lurched and died.
Should I have this looked at or is this a common thing with these bikes? It's still under warranty, but if I take it to the dealer I am sure they are going to tell me they could not duplicate.
2013 Vision Sunset Red - Stage 1 exhaust, VictoryHID Cyclops
2004 Kingpin - Traded
Term is offline
post #2 of 16 (permalink) Old 08-06-2014, 04:05 PM
Longbow3's Avatar
I'm become real careful when I dump the clutch in neutral. I've never had the false neutral issue but I have released the clutch too quickly thinking it was in neutral. It was in first and luckily I had a tight hold on the brake!
2011 Blue Cross Country,
VictoryHID.com HID
1" lowered with Witchdoctor link
Grasshopper driver backrest
2007 Vstar 1100 Silverado (traded)
Longbow3 is offline
post #3 of 16 (permalink) Old 08-06-2014, 04:23 PM
It's probably a very good idea to check if it's really in Neutral. I hardly ever do and I've been lucky so far. I shall check more thoroughly from now on.
post #4 of 16 (permalink) Old 08-06-2014, 04:32 PM
I really dislike how noisy this power plant is, so I decided to try VR1 20W50. The result was a noticeably quieter engine and transmission. The downside was missed shifts, false neutrals and difficulty hitting neutral.
I went back to my favorite oil and the bike returned to normal. Might not have anything to do with your issue but something to consider.
2015 XC Magnum
Smokin Joe's Pipe Mod, Stage 1 flash, Loydz air filter
Backrest and trunk, Corbin Dual tour/heated
Hydraulic Clutch
When it comes, meet it.
MYVIC is offline
post #5 of 16 (permalink) Old 08-07-2014, 07:46 AM
soofle616's Avatar
That's a different definition of false neutral than usual. Typically false neutral describes missing a gear and ending up in "neutral" between two gears because nothing engaged fully. The result is no power delivered to the wheel. In your case it sounds like a fault in the neutral switch circuit and is probably something you should look into. Seems like something is causing the switch to close (open? I don't have a wiring diagram in front of me) when it shouldn't be.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #6 of 16 (permalink) Old 08-07-2014, 08:03 AM
I guess I should read the entire post, my bad
2015 XC Magnum
Hydraulic Clutch
MYVIC is offline
post #7 of 16 (permalink) Old 08-07-2014, 08:28 AM
joelis's Avatar
I actually had it happen ONCE on my 2000 mile trip this past week. I didn't think much of it at the time, but it did make me look a little stupid since it was at a busy 4 way light in downtown Sturgis...
2013 AG XC
- Chrome Tri Ovals Stage 1
- Madstad Shield
- VictoryHID beams
- Kuryakyn Dually Hwy Pegs
- MCC Custom Fork Mount Deflectors
- Chrome Locking Laydown Plate Cover
- Lock & Ride Chrome Passenger Backrest
- Grasshopper Driver Backrest
- Vic Tracker Grips
- more to come...
joelis is offline
post #8 of 16 (permalink) Old 08-07-2014, 09:58 AM
DillPickle311's Avatar
I suggest before going to neutral that you give it a little gas with the clutch engaged and then slowly release to see if you are actually there.
Now, I love the ease of shifting my new to me vegas but these bikes need a neutral assist because finding it sucks. I've tried downshifting to 2nd, stopping, barely touching lever down, and she lights up. This much easier than going to first and then searching for it.
Forget finding it if I stop on a slight hill. I just shut it down and remember to crank it with clutch engaged.
DillPickle311 is offline
post #9 of 16 (permalink) Old 08-07-2014, 09:59 AM
My XCT has a neutral assist. The only downside top it is it's very hard to pop-start if need be.
post #10 of 16 (permalink) Old 08-07-2014, 12:39 PM
joelis's Avatar
Easy to do when you are not in a hurry. But try the scenario where you have a wasp inside your shirt and you are quickly trying to get into neutral to get the wasp out of your shirt...
joelis is offline
