Switched power source that can handle 5 amps - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 08-07-2014, 09:40 PM Thread Starter
ChiTownVegas's Avatar
Default Switched power source that can handle 5 amps
I don't know why the $%^& Victory ran things from the battery, through the fuse block, and THEN to the headlight, horn etc. All the fuses are hot when the bike is off.
Long story short, I am trying to hook up an amplifier and would PREFER to put it under the seat as the headlight is already cramped with 2 HID ballasts. The amp has no switched power source. I know I could wire up a relay, but for simplicity, would just prefer to find a spot I can hook into. 5 amps really isn't that big of a draw and figured there might be something under the saddle to connect to.
In case you can't tell, I haven't pulled it all apart yet. Was hoping someone had some insight for the morning.
2012 Vegas 8 Ball
LLoydz VM1 drop in cams
LLoydz Adjustable Timing Wheel
LLoydz 1/4 turn throttle ring
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
Pirelli Night Dragon rubber
ChiTownVegas is offline
post #2 of 3 (permalink) Old 08-08-2014, 05:37 AM
philmonger's Avatar
Does the Vegas have a heated seat option? If so, look under the seat....
2011 XR Midnight Cherry, Hard Bags, Vic htd grips & seat, Vic medium Windshield, unlocked speedo, Lloydz Air filter, VFC III, Lloydz ATS +4, Vance & Hines slip ons
1993 Vulcan 1500 (sold)
1981 Yamaha Seca 750 (ridden into oblivion)
1977 Honda 550 (sold)
philmonger is offline
post #3 of 3 (permalink) Old 08-08-2014, 07:39 PM Thread Starter
Don't know WHAT I spliced into, but there was a heavy gauge wiring harness under the seat that I connected to. Works perfectly
2012 Vegas 8 Ball
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
