fuel lines - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 08-10-2014, 10:07 PM Thread Starter
Default fuel lines
I bought a used bike that supposedly had a bad fuel pump. I got a new pump but still no start. I also checked for spark and all is good there. I'm beginning to think maybe the folks I got it from may have switched the lines when they were trying to get it going. It's an '01 Standard cruiser. In a schematic I checked, the fuel line from the filter goes to the right side of the bike...opposite the side where the ignition is. Could someone confirm that? The tank return would then be on the left....same as the key. If that is correct then this one is reversed.
keld is offline
post #2 of 12 (permalink) Old 08-10-2014, 10:27 PM
ammo_umb's Avatar
According to the attached link it routes down the right side.
http://www.donwoodvictory.com/fiche_...2001&fveh=5718
Retired USAF, IYAAYAS!
ammo_umb is offline
post #3 of 12 (permalink) Old 08-10-2014, 11:20 PM Thread Starter
Yes, that's the diagram I was looking at. I just went out and switched them but still no start...I'm running out of ideas here.
keld is offline
post #4 of 12 (permalink) Old 08-11-2014, 05:07 AM
GatorJoe's Avatar
If haven't tried it spray a little starting fluid into the air cleaner if cranks right up and dies is definitely a fuel problem ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #5 of 12 (permalink) Old 08-11-2014, 09:00 AM
jocky's Avatar
Also check the plug leads are on the right way round.
2010 Vegas 8 Ball in Bonnie Scotland. ATS, TTI, PCV, VM1 cams, Assault 2-1.
jocky is offline
post #6 of 12 (permalink) Old 08-11-2014, 09:11 AM Thread Starter
I'll try the starting fluid next. I pulled the plugs to check their condition, gap, and for spark. They were dry. I have fuel going to the fuel rail. Is there a way to check for fuel coming out of the injectors?
keld is offline
post #7 of 12 (permalink) Old 08-11-2014, 11:01 AM
If you have been trying to start it and the plugs are DRY then your not getting fuel.
I have to ask do you hear the fuel pump prim when you turn key on.
Just wondering if pump is any good
post #8 of 12 (permalink) Old 08-11-2014, 11:16 AM Thread Starter
Yes fuel pump comes on. I just bought and replaced it. I also pulled the fuel line off and it had fuel to the rail.
keld is offline
post #9 of 12 (permalink) Old 08-12-2014, 08:18 AM Thread Starter
ok guys, I bought a fuel rail tester....tests out 50 + -, just like it should...I have spark, what else could it be?....when I checked the plugs they were dry like no fuel, what else could stop fuel from getting to the cylinders?...I could see one injector being bad, but 2 ???
keld is offline
post #10 of 12 (permalink) Old 08-12-2014, 12:12 PM
Call Rylan at The Vic Shop he will help you
[email protected]
515.339.4313
