Turnsignal issues - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 02-16-2012, 11:07 PM Thread Starter
Default Turnsignal issues
Alright so got an electrical question. When I hit either turn signal, the rear will blink once and then stop. However, the front signal wont flash at all. I have checked relays and fuses. Wondering if it's a ground issue up front causing the problem. Any advice is greatly appreciated. BTW it's an 06 8 ball. Thank you.
Big-D is offline
post #2 of 7 (permalink) Old 02-17-2012, 06:07 AM
handyhoward's Avatar
Start your troubleshooting with the bulbs themselves... don't look at them swap them out with a bulb that you have tested to be good. If that doesn't take care of the problem then step two is the fuses and relays... again swap them out with ones that you have tested to be good. To test for the ground up front just run a loose wire from the chassis to the light and see if they work properly... if so, then ground the front end back to the chassis.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #3 of 7 (permalink) Old 02-17-2012, 08:13 AM Thread Starter
Handy, thank you for the tips. I will be looking more into the issue this weekend. I will share what it was.
Big-D is offline
post #4 of 7 (permalink) Old 02-17-2012, 09:29 AM
NOEMTZ's Avatar
Check your ground...then check your harness underneath rear fender to be sure wire insulation is in tact.
www.noemtz.com
NOEMTZ is online now
post #5 of 7 (permalink) Old 02-20-2012, 02:06 PM Thread Starter
So i went ahead and pulled the rear fender off. Found a lot of taped up sections of rubbed wiring. Looks like a crappy wiring job. So i will be cutting and replacing all the wiring in the back. The front wiring all looked good and im kinda confused as to why i cant get the front signals to work. I checked all grounds. Is there some kind of module or box other than the fuses and relays for signals on these bikes?
2006 8 Ball, Andrews cam, slash cuts, and KN.
Big-D is offline
post #6 of 7 (permalink) Old 02-20-2012, 03:30 PM
the only other box I know of is the auto cancel module for your turn signals, but I believe even when this is blown you still have turn signals just no auto-cancel but I could be wrong
wmskateteam is offline
post #7 of 7 (permalink) Old 02-20-2012, 04:39 PM
NOEMTZ's Avatar
Replied in the other thread....more then likely you fried your ACM.
www.noemtz.com
