CCT pin for passanger pegs - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 08-13-2014, 09:13 AM Thread Starter
Default CCT pin for passanger pegs
Good Morning,
I own a 2013 Cross Country Tourer. The pin that holds the passenger foot board onto the mount keeps walking out over time. Right now I'm tapping it back in about every 600 miles. Anybody else have this problem, and what did you do to keep it firmly seated??
Thanks, Larry
lmartin780 is offline
post #2 of 8 (permalink) Old 08-13-2014, 09:50 AM
Mine do the same thing. Hasn't been annoying enough to seek a solution yet. I'll keep an eye on this thread though.
______________________________________
Hers: 2009 Suzuki C50SE - Cream and Green
His: 2012 Victory XCT - Big Red
Central Missouri
Emack76 is offline
post #3 of 8 (permalink) Old 08-13-2014, 09:52 AM
Other folks have chimed in about that. Some have taken the pin out and reversed it.
post #4 of 8 (permalink) Old 08-13-2014, 10:46 AM
Take the pin out and turn it around so the the pin head faces the front of the bike. Have it so the C clip is facing the back of the bike.
That way the head will alway be tight to the mount.
post #5 of 8 (permalink) Old 08-13-2014, 04:01 PM
I ended up put a snap ring on mine and it hasn't moved yet .
2013 xct bronze
VM1 DR-T "Touring" cams
Lloydz air filter
Timing wheel at 5 deg
Quarter turn throttle
D&D's wrapped
Tuned from The Vic Shop 8/14/15
Dyno 123hp 117tq
Led headlight
Digital guard dawg
HMD gorilla bagger bars
Centermatic wheel balancers
Hydraulic clutch
2015 xct black wife's
Leman crossfire trike kit
Quarter turn
Big gonzo mufflers
2 inch pull back bars
Vm1 cams
Air filter
Timing wheel +2
Pcv
Properly tuned by the vic shop on the street
refuse2 is offline
post #6 of 8 (permalink) Old 08-13-2014, 10:49 PM
Lostintexas's Avatar
Actually you'd want the pin head to the rear. For some reason they vibrate to the front of the bike. Mine does it too but the clip has kept it in so far. Thought about reversing it, but still on the "to do" list.
I ride with the Force.
Lostintexas is offline
post #7 of 8 (permalink) Old 08-14-2014, 08:02 AM
wspollack's Avatar
The pin's walking (a little bit) doesn't bother me, but shortly after I got my XCT, when the pin almost fell out -- and hence the passenger mini-board almost fell off (noticed it a rest stop, with my wife on the trip) -- that was no good.
What happened was that the circlip that goes around the end of the pin had fallen off. I bought an official new Victory circlip, put it on, and then slathered the entire surface around the circlip with red (i.e., "permanent") thread locker... on both the new one and the other side. See pic http://www.billanddot.com/victory-xct/#28 in my gallery. That has worked fine for 2+ years now.
A few folks here have drilled through the pin, near the end, and putter a cotter pin through it. So that's another option.
Cheers,
Bill P.
wspollack is offline
post #8 of 8 (permalink) Old 08-14-2014, 11:06 AM
wspollack great photos.
One of the guys slid a o-ring on the pin then the c clip. The o-ring put drag on the pin makes it harder to loose the pin.
I have the flat end of the pin facing forward for the last 3 years and never had any problems.
