Engine Break-in - Victory Forums - Victory Motorcycle Forum
post #1 of 25 (permalink) Old 02-20-2012, 09:29 PM Thread Starter
atomicdog's Avatar
Default Engine Break-in
For the engine break-in of 0-90 miles...
Originally Posted by 2012 Owners Manual
Do not operate for extended periods of time at throttle positions above
1/3 throttle. Vary the engine speed frequently. Do not operate for
extended periods of time at any one throttle position.
So, how long is an extended period of time?
Thanks,
John
2012 Vegas 8-ball
atomicdog is offline
post #2 of 25 (permalink) Old 02-20-2012, 09:40 PM
Parts need to expand and contract during break in so the rings can mate properly with the cylinders. That's where that statement comes from. The worst thing you can do is drive like a granny. I believe they are talking about the extreme, i.e. 8 hours at 55mph. I drive a new bike just like one with 50k miles. Never had a problem. Common sense prevails.
Check this out it's a good read.
http://www.mototuneusa.com/break_in_secrets.htm
2012 Vegas -D&D slipons, Victory Mini Standard, Tomahawk Bar and rack
2013 GT500
All the toys I need...
USMC341 is offline
post #3 of 25 (permalink) Old 02-21-2012, 12:45 AM
CrossRoads's Avatar
Do not use the cruise control to break in your new bike. Try running compression and decompression runs in each gear. Choose roads that will make you vary the speed and move the bike through the gears. Don't do your first 500 miles on a 500 mile trip you cruise on the highway at a constant speed.
If all else fails, search the forum - this topic has already been beat to death a few times.
CrossRoads is offline
post #4 of 25 (permalink) Old 02-21-2012, 11:26 AM
handyhoward's Avatar
Good advice on the varying run cycles... I always run my bikes and trucks hard when they are brand new. I had a mentor early on in life that told me to break in all vehicles how you expect them to be run later on down the road.
I never get bored with rehashing these topics...
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #5 of 25 (permalink) Old 02-21-2012, 12:15 PM
yup, ride it like you stole it. If you are going to be going on a long trip just make sure you switch gears to vary the RPMs, although you should be able to get through break-in quickly
2011 Victory Cross Roads
gcubed is offline
post #6 of 25 (permalink) Old 02-21-2012, 03:09 PM
In the March issue of CYCLE WORLD magazine, on page 72, the subject is discussed very succinctly in the Service section. +1 on continually vary engine and bike speed / after 100 miles, briefly shoot revs up / never, never lug - keep 'er over 2500 rpm. As the reply in CW states; the manufacturer knows best.
RICZ is online now
post #7 of 25 (permalink) Old 02-21-2012, 05:35 PM
RLJ3RD's Avatar
Does not apply to current cylinder ring material technology.
2017 Magnum X-1
Techno Research Maximus
(Tuned by "801 MotorWorx")
Lloydz LSC Cams
Lloydz Air Filter
Lloydz Turn Throttle Ring
Fuel Tank Lift
U/D Front Pulley
Forged Highway Bars
RC Components RCX Exhaust
National Cycle 8.25in Windscreen
FMB Choppers Phat Apes
Arlen Ness Slash-Cut Grips
Kurakyn Bahn Mirrors
2016 Hammer "S"
-INWORK-
Lloydz VM-1 Cams
Lloydz Torque Tubes
Power Commander V
U/D Front Pulley
RPW Thor Exhaust
Arlen Ness FLY Bars
RLJ3RD is offline
post #8 of 25 (permalink) Old 02-21-2012, 06:27 PM
OK. But the answer to the OP's question is still the same. Vary speeds, don't lug and don't redline.
2013 GT500
USMC341 is offline
post #9 of 25 (permalink) Old 02-21-2012, 07:14 PM
RLJ3RD's Avatar
You are absolutely correct.
2017 Magnum X-1
Lloydz LSC Cams
Lloydz Air Filter
Fuel Tank Lift
U/D Front Pulley
Forged Highway Bars
2016 Hammer "S"
-INWORK-
Lloydz VM-1 Cams
Lloydz Torque Tubes
Power Commander V
U/D Front Pulley
RPW Thor Exhaust
Arlen Ness FLY Bars
RLJ3RD is offline
post #10 of 25 (permalink) Old 02-21-2012, 07:22 PM
saddlebag's Avatar
Do you have a reliable source that could confirm and explain your assertion in some greater depth?
Nevertheless, I agree with the USMC guy. I ride new bikes just like I ride old bikes. If I'm on the highway on a new bike for several miles I might pin the throttle every once in a while, but that's about it.
And even that is probably overkill. A lawnmower is about as old tech as I imagine one could buy and they work for years running at the same engine speed indefinitely.
2011 Cross Roads
saddlebag is offline
