Brake Question - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 08-17-2014, 03:10 PM Thread Starter
Pheonix's Avatar
Default Brake Question
2011 Kingpin. Replaced pads recently. Front good. Rear functions fine, but question:
The outboard side of the calipers pistons are extended fairly far out. The inboard ones are not. It appears that the caliper is in a fixed position where it is bolted to the bracket. Is what I'm seeing normal or does the caliper float and I need to get it "unstuck" and pushed inward so the pistons are extended the same on each side?
2011 Kingpin - Scarlett
Stage I Pipes with Thunder Monsters & NO Catcons
Ness Laydown Plate Holder with Custom Dynamics LED Plate Frame
Custom Ness Engine Covers
V92C Floorboards with NON-LOW Mounts
Ness Ram-Air
PC-V
Lloydz Timing Wheel
Dyno Tuned by 804 Motor Sports
97.26 HP / 110.42 # for now...
Pheonix is offline
post #2 of 8 (permalink) Old 08-18-2014, 08:10 AM Thread Starter
Pheonix's Avatar
Anybody ???
Ness Ram-Air
PC-V
Lloydz Timing Wheel
Pheonix is offline
post #3 of 8 (permalink) Old 08-18-2014, 08:24 AM
Motorbikerx's Avatar
are you questioning the front or the rear caliper?
Rear is floating and only has pistons on one side.
Front is fixed with two pistons either side.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 8 (permalink) Old 08-18-2014, 08:35 AM Thread Starter
Pheonix's Avatar
Rear. When looking at rotor, the pistons are extended out on the outside pad. The inside pad doesn't appear to be pushed inward, away from the caliper towards the rotor. if the rear caliper floats, shouldn't the pads be about the same distance from the inside of the rotor?
Ness Ram-Air
PC-V
Lloydz Timing Wheel
Pheonix is offline
post #5 of 8 (permalink) Old 08-19-2014, 08:22 AM
soofle616's Avatar
There are no pistons on the inboard side because it's a floating caliper. When the pistons on the outboard side extend, the pad on that side contacts the disk, this happens very quickly and does not yet slow the bike. Continuing to press the brake lever will extend the pistons further which will pull the caliper body towards the outboard side until the inboard pad contacts the disk. At this point both pads are in contact and will squeeze the disk to slow the bike. Release the lever and the caliper slides back inboard and the pistons retract a bit so both pads are off the disk. At no point does the inboard pad extend away from the caliper, it will always be in direct contact with the caliper body because there are no pistons on that side.
Check out this page for an interactive animation showing how sliding calipers work: http://auto.howstuffworks.com/auto-p...isc-brake2.htm
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #6 of 8 (permalink) Old 08-19-2014, 09:02 AM
Thanks Soofle...You've explained it a lot better than I could've
Yep!...exactly what he said
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #7 of 8 (permalink) Old 08-19-2014, 09:33 AM Thread Starter
Pheonix's Avatar
Thanks !!! Great explanation....
Ness Ram-Air
PC-V
Lloydz Timing Wheel
Pheonix is offline
post #8 of 8 (permalink) Old 08-19-2014, 11:48 AM
Exactly. You should only be concerned if your pads are not wearing evenly on both sides; this means your caliper cannot slide freely.
