changing fuel filters - Victory Forums - Victory Motorcycle Forum
post #1 of 28 (permalink) Old 08-17-2014, 09:44 PM Thread Starter
Motorbikerx's Avatar
Default changing fuel filters
Searched under fuel /gas filter a few times cant find what I was looking for.
My 2010 Vegas just passed 25,000 miles, my manual on a disc(2012)
states a fuel filter change at 25,000...sure I've seen on here somewhere at 30,000 mile.
Either way its coming up soon so a couple of questions.
To those that have changed theirs already.
Apart from not breaking the fuel nipple under the tank when removing it, do you have any other tips, and stuff to watch out for?
What parts will I need?...presuming the filter setup and tank gasket.
Any links to prices on those U.S. before I get a shock on the prices Australian?
I love racking up the miles on my Vegas , more than any other bike I've owned, only catch is maintenance, I don't want to let slide on the really important stuff.
Theres the fuel filters to do , and rear shock lube,
Fork oil and steering head bearings will be due soon...how vital are these to be freshened as bikes still steering and handling fine.
Right now the in tank fuel filter is my primary concern and wont know how filthy they are till they're out....engines pulling great no sign of fuel starvation.
Any help from those that have already completed this task will be greatly appreciated.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #2 of 28 (permalink) Old 08-17-2014, 10:41 PM
ammo_umb's Avatar
Just did this on mine last week. Took about 20 minutes.
1) Start with your fuel tank on empty then siphon out all you can.
2) Remove the tank and place it upside down on a towel.
3) Remove the bolts from around the fuel pump assembly.
4) Lift the front of the pump assembly and stick a couple finger between it and the tank. Feel for and press on a hose that slightly overlaps the front of the pump assembly (not doing this may results in breakage).
5) Once the assembly is out you will see a white adapter connected to the end of the fuel pump that is held on by a round metal clip. Use a small flat screwdriver placed between the fuel pump and the fuel filter adapter to rock the clip off.
6) To install the new filter place the filter adapter on the fuel pump and put the metal clip on (new filter will come with a new clip). Find a socket that is slightly smaller than the clip, hold the socket on the clip and tap the opposite end with a hammer or wrench until it is flush with the adapter.
7) Remove old gasket and replace with new gasket.
8) Reinstall the pump assembly in the tank and make sure none on the wires (fuel pump wires and fuel level sending unit wires) are caught between the pump assembly and the tank.
9) Reinstall the mounting bolts snugly (there may be a specified torque but I didn't look for it), connect the wiring/fuel line and reinstall your tank.
10) Add fuel and ride
Retired USAF, IYAAYAS!
ammo_umb is offline
post #3 of 28 (permalink) Old 08-17-2014, 11:41 PM
post #4 of 28 (permalink) Old 08-18-2014, 12:17 AM
BP6666VR's Avatar
Subscribed and THANKS
Cross Country Tour 2014 [B]
BP6666VR is offline
post #5 of 28 (permalink) Old 08-18-2014, 02:31 AM Thread Starter
Thanks,
I found a witchdoctors vid on an early model, up to 07 tank but from the sound of your description ammo_umb there must be a change in the tank design and how you access the pump.
Did you take any pix at all?
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #6 of 28 (permalink) Old 08-18-2014, 02:47 AM Thread Starter
All Good!...there is definitly a difference between ours and the early tank, just found it in my manual on disc, fairly detailed with pix, between that and ammo's description I should be okay.
Just need to source the filters and gasket now?
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #7 of 28 (permalink) Old 08-18-2014, 03:27 AM
GatorJoe's Avatar
This is an excellent tutorial will just add the Manual says replace the bolts which I did and the cost was very little .. May not be necessary, but did it because was easy enough to do without spending any big bucks to do so .. Replaced mine at 30,000 and was not bad but still plan on doing again at 60,000 ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #8 of 28 (permalink) Old 08-18-2014, 12:14 PM
ammo_umb's Avatar
No pictures available.
Also for pricing you are sure to be shocked because the filters are ridiculously priced in CONUS. Mine was around $80 USD which is close to 4 times what it should cost.
In order to save some cash next time I'm looking at modding an automotive filter. The OEM is folded in half and the ends are plastic welded so if I can find one the same length with a similar sized outlet I'll connect the ends and attach the OEM hose and adapter.
ammo_umb is offline
post #9 of 28 (permalink) Old 08-18-2014, 12:28 PM
BP6666VR's Avatar
mate, was your filter dirty ? I mean not just color dirty but NOT LETTING enough fuel trough DIRTY????
I have wondered about this and posted about this .....
what would happen if removing the filter ALL from the tank and just putting a high-pressure in-line filter into the system ???
the pump would be FINE as there will be NO debris in any petrol station in the world who could not handle the fuel pump of Victory ???
BP6666VR is offline
post #10 of 28 (permalink) Old 08-18-2014, 01:00 PM
saddlebag's Avatar
After reading Wes Dalton's experience, I was thinking of taking mine to the shop for this. He noted that paint had peeled off beneath where the fuel nozzle fits in the tank. The paint then clogged his up. He got his tank replaced.
I looked in mine and I see the same peeling. If it's going to be a constant issue that ends up killing fuel pumps, then I'll try to see what kind of response I get via my 4 year warranty. Bout time I got around to issuing a claim on it anyway.
2011 Cross Roads
saddlebag is offline
