High Pitch Whine/Whistle from tank? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 02-29-2012, 04:36 PM Thread Starter
SpiritOaks's Avatar
Default High Pitch Whine/Whistle from tank?
Today on my ride home from work I kept hearing this high pitched whine/whistle which I thought was just ringing in my ears (which has a tendency to happen lol). When I got home and got off the bike I noticed that the whine did not move with me so I went back to the bike and tried to figure out where it was coming from.
At first it sounded like it was coming from the speedo... then the idiot light cluster... then it just slowly tapered off. Turned the key back on and cycled the fuel pump and the noise did not return. Started the bike and within 10-15 seconds the noise was back. Shut the bike back off and it continued. Took a short video of it with my phone just to get the sound recorded then waited for it to stop.. which it didn't. So I looked further without much success. Decided to take my stuff into the house and come back out a little later to check to see if it stopped and for some reason I decided to pop open the gas cap... noise abruptly stopped. Started the bike back up and waited for it to come back.. but it didn't. With the release of pressure I can tell that it is a "vacuum" issue but exactly what is causing it?
- Michael
2003 Vegas
2013 Hardball
SpiritOaks is offline
post #2 of 6 (permalink) Old 02-29-2012, 04:44 PM
Goatlocker95's Avatar
Did you check to see if the vent tubes are blocked?
2014 Indian Chieftain
Goatlocker95 is offline
post #3 of 6 (permalink) Old 02-29-2012, 04:54 PM
atomicdog's Avatar
Mine was doing the same thing. From doing a search on the forum I read in a thread to add a thin layer of oil on the gasket of the gas cap. That worked for me.
2012 Vegas 8-ball
atomicdog is offline
post #4 of 6 (permalink) Old 02-29-2012, 05:36 PM
gamewarden's Avatar
I believe you guys hit the nail on the head. If you have ever driven an outboard motor and the gas cap vent was closed or plugged the same thing would happen or the motor would starve of gas. Airlock
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #5 of 6 (permalink) Old 02-29-2012, 06:02 PM
Tarzan's Avatar
My Kingpin used to whistle like that. I found info on another site to fix it. You pull the gas cap apart and there is a little rubber diaphragm that is suppose to relieve the pressure. You just put a small + shaped split in the middle of it and problem solved. That whistling used to drive me nuts.
'14 Ness XC
Tarzan is offline
post #6 of 6 (permalink) Old 03-04-2012, 03:30 PM Thread Starter
SpiritOaks's Avatar
Well I can see that the prior owner of the bike had noticed the issue... I checked around the seal of the cap and sure enough it was a little slick.. there was excess vaseline in a couple spots around the mouth of the tank.
- Michael
2003 Vegas
2013 Hardball
