Need help...V92C died while riding!!! - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 09-17-2014, 08:53 AM Thread Starter
Carl T's Avatar
Default Need help...V92C died while riding!!!
I recently got my bike back on the road and was running fine... Riding last night and it just died, no warning at all other than sluggish start after running for a bit ... Nothing on now with the key on at all... Battery has juice and checked fuses... absolutely nothing now...
Any help would be greatly appreciated!!!
2000 V92C
Custom Paint by Me...
www.helmetpaint.com
Carl T is offline
post #2 of 12 (permalink) Old 09-17-2014, 11:08 AM
If it just died you need to
Check battery bolts with a 10mm wrench. No your hand is not good enough. If the battery is 3 years old it might be shot.
If battery is good and you have headlight but bike will not start your fuel pump might be shot.
Check to see if you have spark.
Tell us more how it will not start does it turn over.
post #3 of 12 (permalink) Old 09-17-2014, 12:15 PM Thread Starter
Carl T's Avatar
Battery terminals good... Battery is fairly new... No head light response no electrical on at all totally dead when turned on nothing at all...Checked fuses nothing burnt... Everything seems good... Always check my headlight to see charging and it was good...
Thank you...
2000 V92C
www.helmetpaint.com
Carl T is offline
post #4 of 12 (permalink) Old 09-17-2014, 01:24 PM
look inside headlight for bad wire. check ground wire going to motor with a wrench.
post #5 of 12 (permalink) Old 09-17-2014, 01:30 PM Thread Starter
Carl T's Avatar
Ok will do thank you...
2000 V92C
www.helmetpaint.com
Carl T is offline
post #6 of 12 (permalink) Old 09-17-2014, 06:17 PM
Maybe your ignition switch failed
post #7 of 12 (permalink) Old 09-18-2014, 04:41 AM Thread Starter
Carl T's Avatar
I went back through the bike and this time checked the fuses with a test light, the ignition fuse was blown... Now every time I put a new fuse in it blows it...
2000 V92C
www.helmetpaint.com
Carl T is offline
post #8 of 12 (permalink) Old 09-18-2014, 11:50 AM
start tracing wire for the bad spot. Look under seat for pinched wire even under gas tank
post #9 of 12 (permalink) Old 09-18-2014, 08:44 PM Thread Starter
Carl T's Avatar
I think your right... Its got to be the ignition...
2000 V92C
www.helmetpaint.com
Carl T is offline
post #10 of 12 (permalink) Old 09-20-2014, 11:39 AM Thread Starter
Carl T's Avatar
Like the fuel pump n oil filter is there an ignition that you can pick up from a regular part store???
2000 V92C
www.helmetpaint.com
Carl T is offline
