2002 Classic Cruiser battery = YTX20HL-BS? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 04-21-2012, 03:12 PM Thread Starter
DaveTV's Avatar
Default 2002 Classic Cruiser battery = YTX20HL-BS?
EDIT: that is the one and only, the "H" is 310cca, the YTX20L is the samd but with 270cca(cold cranking amps)
DaveTV is offline
post #2 of 6 (permalink) Old 02-11-2015, 07:18 AM
Are there any higher cca options out there? My battery only seems to crank hard for one start (on a new battery). I would like something higher. What batteries do you guys prefer?
hypeshipe is offline
post #3 of 6 (permalink) Old 02-11-2015, 07:37 AM
Ghost_Rider's Avatar
I went with an interstate battery for my bike, they were cheapest of the 3 or 4 places I called. Can't remember how many cca it is. It's held up pretty well, but I also keep it on the battery tender when I'm not on it
2003 V92C
Wrapped RPW Slash pipes
K&N air filter
Stebel Nautilus
Viking saddlebags
16" apes
Ghost_Rider is offline
post #4 of 6 (permalink) Old 02-11-2015, 11:48 AM
So have you checked to see if your bike is charging at a good rate. A good battery should crank for some time. Maybe you have dirty throttle bodys or bad compression.
post #5 of 6 (permalink) Old 02-11-2015, 11:50 AM
I think all Vic's come with that battery and works extremely well.
Hope your shoveling is getting better
post #6 of 6 (permalink) Old 02-11-2015, 11:56 AM
I haven't put a multi meter on it but my digital gauge says I'm charging fine. My TB is definitely dirty and I actually just pulled it off of the bike to clean and replace the rubber under it. I'm not sure how a dirty TB could cause this though. It's not that it takes a while to turn over. It's that if I start the bike multiple times in a row, the cranking power is dramatically lower each time.
