02 TC fuel will not stop - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 11 (permalink) Old 12-26-2014, 02:16 PM Thread Starter
Default 02 TC fuel will not stop
I have a 2002 V92tc deluxe and removing the gas tank was a big gas spill mess. I followed the instructions of repair manual, but the gas wouldn't stop flowing once I disconnected the line from the rail. isn't this supposed to work only on vacuum? Also need another gas cap, because this one fell and broke in two pieces. Maybe if I can find only the insides of the gas cap would do.
imgeno2 is offline
post #2 of 11 (permalink) Old 12-26-2014, 04:46 PM
Vicbuilder's Avatar
The fuel pump assembly needs rebuilt. The fuel should not continue to leak out once the tank is removed. If it does that means there is some seal or component that is cracked and leaking fuel past.
The Vic Shop can rebuild your pump assembly for far less than the cost of new. Contact me if interested....
PastorJustin likes this.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
post #3 of 11 (permalink) Old 12-26-2014, 06:29 PM
kevinx's Avatar
What Rylan said
kevinx is offline
post #4 of 11 (permalink) Old 12-27-2014, 09:53 AM Thread Starter
thanks for the reply. I agree that some seal or something isn't working properly. I think this bike is creating a personal relationship with me and wants to know where the luv is. She is pretty enough for me to take her tweaks away. Just hate these little surprises. Can't wait for the spring weather. Happy New Year
imgeno2 is offline
post #5 of 11 (permalink) Old 12-27-2014, 11:19 AM
kevinx's Avatar
Send the pump to Rylan and he can rebuild it for a very reasonable price
kevinx is offline
post #6 of 11 (permalink) Old 12-27-2014, 05:30 PM Thread Starter
It's good to know where we can have things serviced. Can I get Rylan's information? Usually I do my own repairs, but I don't know how and where to get the repair parts. Thanks for the help
imgeno2 is offline
post #7 of 11 (permalink) Old 12-27-2014, 05:32 PM Thread Starter
Do you think that this continuous fuel flow could be the cause of hard starting?
imgeno2 is offline
post #8 of 11 (permalink) Old 12-27-2014, 05:41 PM
Yes for sure.
Clean your throttle body while you have the tank off.
Send Rylan your pump and have it done the first time right. If you screw up one o-ring you'll have to start all over.
Don't be cheap
post #9 of 11 (permalink) Old 12-27-2014, 05:56 PM
Vicbuilder's Avatar
Kind of. The continuous flow would indicate a leak in the assembly, which will make the fuel pressure low, and THAT would cause the hard starting.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
post #10 of 11 (permalink) Old 12-27-2014, 10:01 PM
kevinx's Avatar
Rylan is Vicbuilder. His number is on his signature in the posts on this thread.
kevinx is offline
