00 SC Front Wheel Removal - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 06-14-2012, 04:43 PM Thread Starter
Default 00 SC Front Wheel Removal
Hey, I've got a 2000 SC that I need to change the front tire. I wouldn't have thought getting the axle out was that big a deal but it seems to be fighting me. I've got the brakes off, 1 hex head loose but the other side is giving me the problem.
Any tricks I should know? I'd appreciate any help you can give me
Scrider54 is offline
post #2 of 4 (permalink) Old 06-14-2012, 05:15 PM Thread Starter
Okay, I must have had one of those senior moments they talk about, I just forgot to loosen 2 of the pinch bolts, DUH
If I knew how I'd delete this but!!!!!!!
post #3 of 4 (permalink) Old 06-14-2012, 05:26 PM
Seniors don't get those moments your guys rushing around with there heads cut off get them
post #4 of 4 (permalink) Old 06-14-2012, 11:27 PM
Tims_04V92TC's Avatar
Scrider, not trying to jump in your wrench turning but reading this I just wanted to remind you during reassambly to torque the 2 pinch bolts on the axle side fork, then torque the axle nut and finally the two remaining pinch bolts on the axle nut side. German torque value of "GoodEnTIGHT" may cause you a head ach on down the road. Safe ridin!!!
Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
