01 V-92C Fuel Leak - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 06-27-2012, 07:06 AM Thread Starter
Default 01 V-92C Fuel Leak
Hi,
I went to leave for work this morning, and noticed something dripping on the driveway as I was backing out. After closer inspection, I found that it was leaking gas. I cant see it, but it's dripping straight down on the oil filter. It quits when it not running. Didn't have time to investigate as I was running late. Anyone have this happen, or can you give me an idea of where to start looking this evening. Return line possibly??
Thanks in advance
electgenguy is offline
post #2 of 8 (permalink) Old 06-27-2012, 09:24 AM
cornfedboy2000's Avatar
If I'm not mistaken, the fuel pump and filter are below the shock under the seat. My guess is one of those connections.
cornfedboy2000 is offline
post #3 of 8 (permalink) Old 06-27-2012, 10:35 AM
I don't understand how something is leaking and you start the bike and it stops leaking.
Makes me think you have to much gas in the tank and its coming out the over flow tube. Gas expands in hot weather and if the tank was full then it will over flow. Now you start bike and motor starts to use your gas.
Was your tank full to the top.
post #4 of 8 (permalink) Old 06-27-2012, 04:20 PM
Originally Posted by electgenguy View Post
Hi,
Thanks in advance
It sounds like perhaps a pinhole in the line from the output of the fuel pump; it's a formed "U" shape hose that goes from the bottom of the fuel pump to the fuel filter.
Had the same thing happen to me, except it wasn't dripping, it was gushing! I was lucky - it let go just as I was parking at work; 5 minutes earlier, it would've been spewing fuel right in front of the rear tire at 70 mph...
'99 V92C with K&N, PMRT chip, Vic stage 1 slipons, and engine by Rylan Vos!
Colorado Expat is offline
post #5 of 8 (permalink) Old 06-27-2012, 10:38 PM Thread Starter
So I get home from work this evening, remove the seat and side covers. I can visually see the pump and filter. I can also see the "U" shaped fuel line and the associated hose clamps. Everything looks fine and the clamps are tight. Here is where it gets really wierd. I start it up, and it doesn't leak a drop. This morning it was dripping down on the oil filter, but only when it was running. When I shut it off to inspect, it quit. Absolutly no idea whats going on now.
post #6 of 8 (permalink) Old 06-27-2012, 10:41 PM Thread Starter
Tank isn't full, probably 3/4 at most. I dont see an overflow that exits at the rear of the engine above the oil filter, as this was where it was coming from this morning. Only leaked when the engine was running.
post #7 of 8 (permalink) Old 06-29-2012, 06:39 AM Thread Starter
FOLLOW UP..... 2 days later, and still no leaks. Still not sure what the problem was, but it hasn't leaked a drop of gas since. I can only assume it was coming from the overflow for some reason. Will continue to monitor.
post #8 of 8 (permalink) Old 06-29-2012, 08:33 AM
Azdave's Avatar
I filled up and I had a small leak from the overflow. First time that ever happened and has not happened since. Hopefully overflow issue due to heat
Blame it on me
2014 HD Street Glide
2013 Vision Sunset Red
2006 Jackpot sold
2006 Vrod Screaming Eagle (sold)
1972 Kawasaki 1000
Azdave is offline
