Leaking fuel, whats this part called? - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 07-02-2012, 01:56 PM Thread Starter
Default Leaking fuel, whats this part called?
Hey guys/gals, finally found my leak!
Whats this white "T" called in my pic below? It appears to be leaking from near that piece of metal with the spring behind it.. I'm loosing nearly 1/8 gallon a night
I tried searching but my phone wont show pics
Thank you in advance!!
The road to hell is paved with good intentions.
2001 Victory V92c Deluxe
Ryan... is offline
post #2 of 15 (permalink) Old 07-02-2012, 04:56 PM
kevinx's Avatar
That is the fuel quick disconnect, and the bottom half is discontinued.
The good news is that failure 99.9% the top half
kevinx is offline
post #3 of 15 (permalink) Old 07-02-2012, 06:31 PM
OldGringo's Avatar
Ryan, stupid question on my part but did you try to reinsert the male connector into the female port in the tee to see if it would reseat?
When I got my 01 it had a brass tee in it that made it a real pain to clamp off for tank removal.
Ride hard,
Gringo
Thin Blue Line LEMC
01 V92C
09 Vision
OldGringo is offline
post #4 of 15 (permalink) Old 07-03-2012, 02:18 AM Thread Starter
Thanks for the info! On most of the online parts catalogs all I can see available now is an o-ring (part 21)
http://www.polarispartspitstop.com/p...CC/21193/40661
If the o-ring isn't going to fix the leak, couldn't I just replace it with a solid metal "T" of the same diameter?
No, I didn't remove anything because I could actually see gas running down the valve, so I had just assumed it was either the o-ring or the entire valve was faulty. I didn't see any brass connectors anywhere
Ryan... is offline
post #5 of 15 (permalink) Old 07-03-2012, 12:18 PM
Speaking from experience here...
When you reassemble the quick-disconnect, make sure you are pushing the metal tab on the female part all the way in while reinserting the male part - if you rely on the stop, you run a good chance of shaving a bit off the o-ring as it's reinserted, causing a leak...
The o-ring is a standard size item - not Vic specific.
Also, when working with the q-d, you want to pull / push it straight out / in - don't get it cocked at an angle, lest it break (which it will, given half a chance - especially if it has a few years on it).
'99 V92C with K&N, PMRT chip, Vic stage 1 slipons, and engine by Rylan Vos!
Colorado Expat is offline
post #6 of 15 (permalink) Old 07-03-2012, 12:38 PM Thread Starter
Well its already broken, I snapped it when I tried removing it today
So I'm now looking for a T section with 3/8" tops and a 1/2" bottom, which is starting to feel damn near impossible.
Ryan... is offline
post #7 of 15 (permalink) Old 07-03-2012, 06:38 PM
That quick-disconnect is probably the item which causes the most blue language from owners of the early bikes... The female part does have a non-Vic source, but the "T" male was made specifically for Vic, and there's no direct replacement out there.
Some people have researched substitutions from the McMaster-Carr catalog and other industrial supply houses, but none are direct replacements; fitting oversized components in there can be difficult, and usually hoses need to be trimmed to fit it all together.
As KevinX said, the top part is still available - I'd bite the bullet (while cursing the price) & buy two while you still can... (Come to think of it, I should follow my own advice!)
What I think would be perfect would be a 3-way plug valve with "T" passages, enabling the 2 side ports in and the center out; turn the valve plug 180 degrees, and the outlet is blocked. Unfortunately, I've not yet found any... (Not for lack of trying, though!)
post #8 of 15 (permalink) Old 07-04-2012, 07:40 PM
Does anyone have the part # to the top portion of the tee quick disconnect valve that is still available?
Thanks
electgenguy is offline
post #9 of 15 (permalink) Old 07-04-2012, 08:21 PM
NOEMTZ's Avatar
I see # 2520131
www.noemtz.com
NOEMTZ is offline
post #10 of 15 (permalink) Old 07-04-2012, 10:31 PM
Thanks NOEMTZ..!! Any line on the best place to get one?
