2001 V-92 Fuel Filter - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 07-11-2012, 08:28 PM Thread Starter
Default 2001 V-92 Fuel Filter
Anyone happen to know if there is any reason that an aftermarket fuel filter wouldn't work for the V92's? Victory wants $25 for an OEM. If anyone has used a Wix or another aftermarket filter, part numbers would be appreciated.
Also, is there an easier way to remove the fuel filter...I ended up removing the mono-shock. I couldn't see any other way to change it.
Thanks
1989 Honda Pacific Coast - Corbin Touring Seat, Markland Cruise, J&M CB, Argus Battery Bug, Dunlop E3's.
2001 Vic V92C - Corbin Touring Seat, K&N, Stage I, NGK Iridiums,Dunlop E3's
2003 Triumph Speedmaster - Triumph Off Road Pipes, Progressive Suspension W/ 2" Lowering Kit, Kuryakyn Grips, Tons of Chrome
2004 Honda VTX 1300 C - Stage I, Barons Big Air Kit, Progressive Suspension, Vance and Hines Big Shots, Kuryakyn Grips, Chrome Chrome Chrome.
Location - Kansas
electgenguy is offline
post #2 of 6 (permalink) Old 07-15-2012, 09:58 PM
Dann's Avatar
Default Fuel Filter
I dont see why a automotive filter wouldn't work. I don't know what
the fuel pressure is on a victory but most cars is about 60 to 70
psi. Take it to a parts store and see if you can match up the size so
it will mount correctly. That's my 2 cents. Good luck and let us know
how it works out.
Cedar Lake Indiana
V92c Standard Cruiser
Dann is offline
post #3 of 6 (permalink) Old 07-25-2012, 05:49 AM
cornfedboy2000's Avatar
Just bumping this to see if you had any luck?
cornfedboy2000 is offline
post #4 of 6 (permalink) Old 07-25-2012, 06:11 PM
OldGringo's Avatar
I believe it to be a Wix #33310?
Ride hard,
Gringo
Thin Blue Line LEMC
01 V92C
09 Vision
OldGringo is offline
post #5 of 6 (permalink) Old 07-26-2012, 08:24 PM Thread Starter
CFB.......No Luck. I tried going the auto parts store route, and actually tried two different ones, but with the numb nuts they have working there nowadays, if they cant pull it up on a computer, they are lost. Ended up going back with the Victory filter. Also replaced 3 fuel lines, and bought a spare quick connect all of which cost me $110. RIDICILOUS, but it did fix the leaking problem.
Location - Kansas
post #6 of 6 (permalink) Old 07-26-2012, 08:31 PM
Sounds about right... I just ordered a new pump and filter from the Vic shop... when I pull the old ones I'll see what my contact at walbro can do... maybe there's a chance
