motor swamp - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 04-24-2015, 02:32 PM Thread Starter
Thumbs up motor swamp
, I have a 2001 sc and I thinking about a motor swap . will a freedom 110 ci 6 speed work , or do I have use a freedom 5 speed 110 ci motor being a better choice .
thanks ,
g.
flybyvfr123 is offline
post #2 of 8 (permalink) Old 04-24-2015, 06:12 PM
no 110 6 speed will not fit.
I don't believe the 110 5 speed will fit either
If your looking for a motor Rylan at "The Vic Shop" has a motor for sale
post #3 of 8 (permalink) Old 04-24-2015, 06:44 PM
Motorbikerx's Avatar
Thought youd flooded it for a second there.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 8 (permalink) Old 04-24-2015, 10:14 PM
BP6666VR's Avatar
http://thekneeslider.com/bad-dog-215-cubic-inch-v-twin/
Swamp-vic cool
I cannot help you with your answer but the titel intreged me, keep is updated what your gonne do, and post some pictures when your ready?
Cross Country Tour 2014 [B]
BP6666VR is offline
post #5 of 8 (permalink) Old 04-25-2015, 07:53 PM
Chuck Kull's Avatar
What about a 106 with a 6 speed? Will that fit? I saw this one on ebay.
http://www.ebay.com/itm/171535130482...%3AMEBIDX%3AIT
2002 Victory V92C
Yoder, Colorado
Chuck Kull is offline
post #6 of 8 (permalink) Old 04-26-2015, 11:56 AM
NO its to big for your frame.
Send your motor to the Vic Shop and for a few thousand he can make it faster then a 106
post #7 of 8 (permalink) Old 04-26-2015, 08:24 PM
Are the earlier freedom 92's that much of a difference? I know I've seen them in the early vics. Rylan would be the guy that knows give the vic shop a call. He probably has an engine for you.
2011 vegas 8ball PCV, swept pipes rpw modified baffles, llyodz vm1-dr cam, ats +4, 1/4 throttle, ud pulley and ness intake.
KMC tuned 114hp/125ft/lbs
shanko is offline
post #8 of 8 (permalink) Old 05-23-2015, 05:30 AM
The only swap engines that fit our frames are Freedom 92 engines from 2002-2005 I think? 1999-2001 engines are "Hammer" 92C 1st generation engines.
LTC, U.S. Army
2001 V92C
2004 Triumph Bonneville
2011 Kawasaki Ninja 1000
cptarmy2002 is offline
