fuel tank replacement options - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 05-15-2015, 03:42 PM Thread Starter
Default fuel tank replacement options
I have a 2000 v92sc and need/want to replace the fuel tank with a newer style if possible. My tank is leaking fuel from the vent port on the underside of the tank. Or how do I fix my tank? Any advice/help greatly appreciated.
Briklayr is offline
post #2 of 3 (permalink) Old 05-15-2015, 09:41 PM
ByteN2it's Avatar
I would try and work with what you have.You might just have a leaky vent hose. If you happen to have a red SC this one might work with a little clean up/coating-or possibly a paint job in your future?
a bit crusty
http://www.ebay.com/itm/00-Polaris-V...item2ec64aaa85
a bit better
http://www.ebay.com/itm/01-Polaris-V...item2c82e1bd07
a nice clean one but would need paint
http://www.ebay.com/itm/01-Polaris-V...item487d78ff0c
ByteN2it is offline
post #3 of 3 (permalink) Old 05-24-2015, 09:52 PM
mine had the fuel line under the tank not the one under the seat start to leak, i removed the tank and found out the line hd dry rotted from the hot and cold of being so close to the engine, if thats not it then why dont you just flip it upside down and cake on some quick steele or gasket sealer to stop the leak, seems much easier and timley/cost effective then replacing the tank!
69DodgeDart is offline
