04 TC, converting to a Harley drive belt and rear sprocket? - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 13 (permalink) Old 05-08-2016, 08:52 AM Thread Starter
saintdruss13's Avatar
Default 04 TC, converting to a Harley drive belt and rear sprocket?
I read a post where a guy replaced the drive belt and rear sprocket with one from a sportster I believe. Anyone know anything about doing this? My 04 TC keeps snapping belts after about 20.000 miles, I'm on my third belt and coming up on 80,000 miles so I'm getting ready for it. I don't know what the deal is with the belts, I have a 05 Vegas that doesn't have this issue so I don't think it's me. I've ran the belts at spec and as loose as I could get away with and still they break right at the 20,000 mile mark.
Captain Spalding's Fried chicken and gasoline. * EXIT 13 OFF ROUT 1 at RUGGSVILLE*
2004 TC, 05 Vegas 8Ball, 09 Yamaha FZ6R
Lake Havasu City AZ.
saintdruss13 is offline
post #2 of 13 (permalink) Old 05-08-2016, 09:01 AM
BP6666VR's Avatar
No mate ... The Under Drive Pulleys on Jackpot need a HD belt coz it is shorter, BUT the HD belt is LESS quality then the VIC belt, trust me I know ....
You are on your third belt ?? Whouw .... I think these belts are indistucteble .... Must be a line-up problem or rear pulley problem or something else ??
TaPaTaLk for VIC forum
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 13 (permalink) Old 05-08-2016, 09:04 AM
Motorbikerx's Avatar
60,000 miles on mine and last half of that with a central stone hole.
The belts are tough.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 13 (permalink) Old 05-08-2016, 11:30 AM
under drive pulley you use a Buel belt. Don't believe you use the rear pulley.
If your belt it is braking at 20K I'm guessing your running the belt to tight. The belt has to be adjusted when its cold. It will become tight when it gets hot.
With wheel off ground you should have 1/2" un and down play in several spots.
Half Crazy is the buy that knows about under drive pulley and belt
post #5 of 13 (permalink) Old 05-10-2016, 12:44 AM
lightweightstickers's Avatar
Default belt to chain conversion
Well, I am the guy that converted to a chain.
It took a LOT of machine work. I bought a Harley sprocket and machined the middle out of it. I then took the stock front Vic sprocket and machined the outside down so that all I had left was the splines in the hub. The first one I welded, which failed due to the heat treating process of the sprockets. The next one I made a bolt together unit with shear pins.
I agree with other posters. Chain drive doesn't sound like solution for you. Have you checked alignment, sharp edges that belt could be rubbing on when suspension moves? Feel the sprockets and check for sharp edges.
I loaded some pics of the chain conversion process. Also, I bought a blank rear sprocket, which I machined to fit bolt pattern of rear wheel.
03 V92TC bobbed
All custom parts by Me.
Grand Junction, Co
lightweightstickers is offline
post #6 of 13 (permalink) Old 05-10-2016, 09:53 AM
Colonel's Avatar
Default Maii Drive Belt Specs
this reply doesn't directly relate to your issue, but seeing your responses, I thought one of you might be able to tell me the width and teeth specs of my 05 92TC. I know the part number but no Vic dealer can seem to give me the specs. Dealer maintenance guys have even looked it up on the Tech Manual and can't find it. Thanks
Last edited by Colonel; 05-10-2016 at 09:57 AM. Reason: My computer failed to enter some of the identifying data.
Colonel is offline
post #7 of 13 (permalink) Old 05-10-2016, 11:20 AM
ByteN2it's Avatar
A loose belt is actually more likely to break as the teeth will try and ride up & over the sprockets making them super tight repeatedly & cause the belt to fail-to tight's not great either but it's a constant force rather than the tension spikes that a to loose belt will experience in it's shortened life. It takes some fiddling around to find the belts happy spot but i don't see going to a different brand belt/sprockets as being an upgrade.
Doug Coffey likes this.
ByteN2it is offline
post #8 of 13 (permalink) Old 05-10-2016, 11:27 AM
rear sprocket is 64 tooth front drive sprocket is 30 tooth
the belt width 28mm
could not find any place that gave a good belt teeth count.
Did find one place that said 135 teeth but I'm not sure
post #9 of 13 (permalink) Old 05-10-2016, 07:29 PM
A patient man could count them after marking the first one.
I'm not that man.
post #10 of 13 (permalink) Old 06-23-2016, 12:59 PM
Mine broke at about 7500 miles. I've been told that is unusual. I have about 13000 on the new belt. I just got new tires, with the cool $50. Dunlop rebate, and the shop didn't see any problems with the belt.
Cloverdale, Calif.
V92TC
(The fast blue one)
Bugkiller is offline
