Best belt tension gauge, and 'rear wheel alignment tool' - Victory Forums - Victory Motorcycle Forum
 15Likes
post #1 of 28 (permalink) Old 05-14-2016, 02:32 PM Thread Starter
Carl92's Avatar
Default Best belt tension gauge, and 'rear wheel alignment tool'
Was looking for some help finding the tools helpful in adjusting belt tension, and rear wheel alignment.
I understand there are a couple 'homebrew' methods, but I'd like some help getting me in the ballpark easier.
Victory's part number for a belt tension gauge is : PV-43532
Rear wheel alignment tool part number is : PV-43528
Having trouble finding them online, and am also wondering if there is a decent off-brand model, that may work just as well and save a little change.
Appreciate any input
2001 Victory V92C
Carl92 is offline
post #2 of 28 (permalink) Old 05-14-2016, 05:06 PM
NAPA has one all bearing and belt stores carries them.
Even Harley there is nothing special about the tool
Belt Tension Gauge OTC 4748 | NAPA Auto Parts
visionjohnny is online now
post #3 of 28 (permalink) Old 05-14-2016, 05:09 PM
for alignment. Get rear wheel off ground. sit on the ground and spin wheel and look to see if belt is in straight line. You can see if its hooking one way or the other.
Of course you want belt in straight line
post #4 of 28 (permalink) Old 05-14-2016, 09:17 PM
These folks say they are presently working on a Belt Monkey, so I'm patiently waiting.
Tru-Tension | Precision Every Time | Chain Monkey
visionjohnny likes this.
post #5 of 28 (permalink) Old 05-14-2016, 09:54 PM
BP6666VR's Avatar
Home brew ?? Mate everything in the world is made by guys tinkering around in company's .... Most patents are from guys working in a company who have a golden idea, but don't have the resources to patent the product ... Just coz it's made out of chrome doesn't mean it is better ... A guy works for a company, makes a bullet proof product, the company mass-produce this with cutting corners to make it cheaper ..
I found that this simple belt gauge worked a bit complicated / pushing / measuring / etc ...
So I made this contraption in 1 hour time ..,
Hope you liked my home brew improvement to a annoying stock tool ... You can clearly see that you do not need a mm measure tool with this set-up as the 2 black marks will mark the deflection and the two O-ring the force or Kilogramme
See the manual for that
TaPaTaLk for VIC forum
Cross Country Tour 2014 [B]
BP6666VR is offline
post #6 of 28 (permalink) Old 05-15-2016, 12:37 AM
Ain't you the clever one. I'm going to make me one, thanks to you.
BP6666VR likes this.
post #7 of 28 (permalink) Old 05-15-2016, 06:41 AM Thread Starter
Carl92's Avatar
Thanks guys.
Cool lookin rig ya made, I didn't mean homebrew in a bad way, i love homebrews haha
Just lookin for info for the tools the manual recommends so I can find my own combo to see what works best for me
2001 Victory V92C
Carl92 is offline
post #8 of 28 (permalink) Old 05-15-2016, 06:59 AM
BP6666VR's Avatar
Ya mate, when I read it back, I didn't mean anything but a gentle joke ....
Anyway this thing works glorious, used it on my bike and a HD DEUCE ... Easy as pie ... It's hanging on my tool board ..
BP6666VR is offline
post #9 of 28 (permalink) Old 05-15-2016, 07:41 AM
Motorbikerx's Avatar
belt tension gauge?? yep!...got one in my hand!..called a finger.
Pushing up on the belt cold got 1/2 to 3/4" movement that vanishes to around 3/8" hot, a bit slack is much better than too tight.
In 60,000 miles and 8 tyre changes haven't touched tension or alignment.
Once the initial stretch is taken care of at the first service there's no real need to fark around with it,..as long as your tyre shop don't go playing with the adjustment it stays static.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 28 (permalink) Old 05-15-2016, 07:53 AM
LILMAGS500's Avatar
I use my hands , my mind , and go by feel ... As far as aligning the belt I go strictly by the manual . This has worked well for me . I also adjust my belt when warm , as not to ever have it too tight . Doing it this way has also eliminated all belt chirp wet or dry .
Motorbikerx and rustychevelle like this.
LILMAGS500 is offline
