AC Delco Battery Failure - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 06-13-2016, 11:00 AM Thread Starter
knukey's Avatar
Default AC Delco Battery Failure
I tried the AC Delco battery in my V92C (had it three years) and it still holds charge and works but the termials failed. I got stranded last fall for a battery issue. The leads were loose so I tightened them and all was good (though I did have to be towed around 30 miles). On Saturday it started acting up again so I went to check the terminals and found this. I have no idea how this happened, I certainly did NOT crank down so hard as to shear BOTH terminals. I used a screw driver not even a ratchet.
I hope to have better service with the Interstate Cycle-tron II High Performance I just installed.
1999 V92C, Corbin, 16" Apes
knukey is offline
post #2 of 4 (permalink) Old 06-13-2016, 12:01 PM
I would stick with motorcycle specific battery manufacturers products. Vic battery bolts have a tendency to loosen, so one should always place lock washers under then. Based on the photo, I'd say that the terminal material was too brittle and the bolts were torqued on too much.
post #3 of 4 (permalink) Old 06-13-2016, 12:35 PM
ByteN2it's Avatar
After trying some other brands I've gone back to using the OEM Yausa batteries-they are great and if you use a battery tender you can extend their service life even further. This link was posted on another site, it's a great price-just use the promo code for a $70.83 battery delivered to your door.
https://jet.com/product/YUASA-YTX20....bGPbsgmQErRFdw
ByteN2it is offline
post #4 of 4 (permalink) Old 06-13-2016, 03:37 PM
rhino 2's Avatar
Looks like a classic case of over tightening...
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
