2000 V92C Power surges...Transmission going? - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By vindex1963
post #1 of 3 (permalink) Old 07-05-2016, 01:46 PM Thread Starter
Default 2000 V92C Power surges...Transmission going?
hi guys
I dont have much time to take my bike out....probably less than 300 miles annually.
The transmission always had "clunked" when shifting gears. Now when I am cruising (but not accelerating) my bike sort of surges, like it may be slipping? The engine's rpms do not change but i definitely feel the power surge, which goes away when I add to the throttle.
Thoughts??
TIA.
Nikon.
Nikon is offline
post #2 of 3 (permalink) Old 07-05-2016, 06:06 PM
Motorbikerx's Avatar
May not help but my thoughts are.
It's very hard to put feelings on bike behavior down on paper(?)
To get the feeling across of what's happening inside it.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 3 (permalink) Old 07-05-2016, 07:23 PM
vindex1963's Avatar
Sounds like a lean surge to me with the age of the bike my money is on a cracked intake boot.
Motorbikerx likes this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
