V92C Brakes Overheating. - Victory Forums - Victory Motorcycle Forum
 37Likes
post #1 of 60 (permalink) Old 07-17-2017, 03:09 PM Thread Starter
Default V92C Brakes Overheating.
Hello to all. I recently bought a beautiful 2000 V92C. What a nice bike it is. When I ride and use the brakes as normal, I become aware of severe fade on the real brake. When I check, the rotor is very hot, much hotter than the front. After cooling down, a view of the pads still installed showed like new thickness. The real wheel spins, but not completely freely. It moves easily, but stops when I stop pushing. While spinning the wheel, I can apply the brakes, and they stop the wheel, and release. I do notice (sometimes) a creak or groan from the caliper when the brake are applied and released. Another test ride has the same problem. Here are my questions. How freely should a rear wheel spin, with the drive belt in place? Is this a caliper release problem? It seems that new calipers are not out there. I have found a rebuild kit on Ebay. Any thoughts are appreciated. I did flush and bleed the brake, also.
Mark Whisenant is offline
post #2 of 60 (permalink) Old 07-17-2017, 03:39 PM
I have a friend who had the same problem. Turns out he was riding the brake pedal. When I told him that, he denied it. I told him to pay attention and sho nuff, he was on the brake ever so lightly, but on it.
FYI, The rear brake is for hard stops in concert with the fronts and trail braking in the twisties ONLY....IMO. I never wear out rear pads. Really.
post #3 of 60 (permalink) Old 07-17-2017, 03:45 PM Thread Starter
RICZ, thanks for the response. I am 57, and have learned that I am capable of almost anything foolish. I will pay careful attention my next ride.
SkInM4N likes this.
post #4 of 60 (permalink) Old 07-17-2017, 03:47 PM
Perhaps the rear pads are new and just haven't seated yet?
SkInM4N likes this.
post #5 of 60 (permalink) Old 07-17-2017, 03:57 PM
You might want to check to see if the pads have glazed over. If they have, lay sandpaper on a flat surface and give 'em a few strokes. Be sure to clean off the grit. Spray some brake parts cleaner on a cloth and wipe off the disc on both sides while the pads are out. If there's glazing on the disc, clean it with a green Scotchbrite pad and then wipe with brake parts cleaner.
I'm 80 and have had a lot more practice at screwing up.
541RF and SkInM4N like this.
post #6 of 60 (permalink) Old 07-17-2017, 05:56 PM
3 other things that will cause that.
Brake master cylinder completely full. No room for expansion as the brake system comes up to temperature.
Brakes that are not bled properly. The caliper pistons will not pull back when the pedal is released because there is air in the system.
The cure is to bleed the brakes again.
The other thing is sticking pistons. Pull the caliper, pull the pads and push the pedal while watching the pistons.
If one is hanging up, not moving out that is your problem.
Depending on the construction of the caliper, you may have to remove the outer rubber dust seal if it has one them, then wash the pistons off with chlorinated brake cleaner. Most calipers now days don't have the rubber dust covers. The ones in this video are pretty typical of ones without dust seals. If this caliper had a dust seal, you would see a rubber boot behind the pad that snapped into a grove in the piston and a groove in the caliper housing. There would be a small retainer. Remove the boot to access the piston.
Here is a video that gives you the basic idea of what I am describing.
Start by washing as much crud as you can out.
When I do it I take the pads out. Then I use a piece of metal about 1/4" thick, couple of wooden door shims back to back etc to work out the pistons that are sticky. I block the pistons that do want to move so that they can't move. This will force the stuck pistons to move when you apply pressure to the pedal.
Wash everything out good. Try it. Block the pistons that move freely to force the stuck ones to move. Wash the crud out of the stuck ones, repeat. Push the pistons back in some if you need to being careful not to damage them.
When everything is moving freely all is good. If you still don't see the pistons retract a little when you let off the pedal you have air in the system or the brake fluid has too much water in it and needs to be changed.
Chlorinated brake cleaner is nasty stuff, for this use it works far better than the non chlorinated type. Wear rubber gloves and have plenty of ventilation, as in push the bike outside. That stuff will shorten your life if your not careful and it will do it very quickly.
So beware. Don't breath it and don't get it on you or your bike. As you work the pistons out while cleaning them keep an eye on your brake fluid level so that you do not run the master-cylinder empty and pump air into the system. That would suck. If you end up adding fluid to the mastercylinder be sure to keep an eye on the level as you push the pistons back in to reassemble it or you will over flow the reservoir.
When your all done remove any fluid above the full mark on the reservoir so the brake fluid has room to expand in use.
Hope that helps.
BP6666VR, swiftdescent and SkInM4N like this.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #7 of 60 (permalink) Old 07-17-2017, 06:03 PM
For the best brake bleed job you will ever do get a set of Speed Bleeders. And they make the task of brake bleeding a one person job and stupid easy. Best to order by phone to make certain you get the correct ones.
Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
post #8 of 60 (permalink) Old 07-17-2017, 06:34 PM Thread Starter
Wow. Thanks Joe!
SkInM4N likes this.
post #9 of 60 (permalink) Old 07-17-2017, 06:34 PM
Motorbikerx's Avatar
https://www.youtube.com/watch?v=csLVVDA5YXk
Hope that helps.
Sound advice there Joe.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 60 (permalink) Old 07-17-2017, 10:06 PM
BP6666VR's Avatar
@MarkWhisenant let us know what you find, some GOOD advice here.....
Side note if there would be air in your rear caliper , then when you ride and the caliper gets hot, it will even push 1 side out more then the other... Then when the brakes cool down there would be less "drag"
All the guys have some solid advice that is easy to follow...
PS did you download the shopmanual already?
Andre using TaPaTaLk
SkInM4N likes this.
Cross Country Tour 2014 [B]
BP6666VR is offline
